Help choosing a blu ray
recover
recover Posts: 14
edited March 2011 in Electronics
I pained on getting this onkyo blue ray and then I ran across this review and it had me 2nd geussing myself. This review claims that the onkyo doesn't support netflixs but on onkyos page it shows that it does.
I plain on using my blue ray for movies(netflix and blu ray etc.) and listening to my cd's. I already have the onkyo 708 receiver that's why I wanted this blu ray to match it up. The Oppo looks interesting also but I'm obviously open for suggestions.
http://www.audioholics.com/reviews/transports/high-definition-dvd-players-hd-dvd-blu-ray/onkyo-thx-certified-bd-sp808-blu-ray-player-first-look
Post edited by recover on
  • Gulfstrings
    Gulfstrings Posts: 313
    edited March 2011
    I've been quietly shopping for a Blu Ray player myself that would be used for movies only ... not too interested in streaming.
    I have Onkyo's DX7555 CD player from a couple years back and, IMO, it's an awesome piece both from performance and build quality. Logic suggested I consider Onkyo's BDP as well - and I'm still looking. I'm more in to items that are built well and do what they're supposed to do and much less intersted in missing features I don't use.
    I saw this review and found it a bit short on specifics. I may look further for more in depth reviews of this machine but right now just coasting though not ruling this unit out because of this article.
    Marantz AV7005
    Marantz MM7055
    Onkyo DX-755 CdP
    Oppo BDP-93
    Technics SL-1301/Shure M97xE
    Polk RTi A7s
    Polk CSi A6
    Polk FXi A6s
    Velodyne VDR10-BV
    Panamax M5100-PM
    Antec VERIS A/V Cooler x 2
  • thuffman03
    thuffman03 Posts: 1,325
    edited March 2011
    IMO, the best bang for the buck in BR players is the Sony PS3.
    Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
  • ViperZ
    ViperZ Posts: 2,046
    edited March 2011
    PS3 is an obvious choice if you want 'do it all'. If you want "audiophile grade", then Oppo is another obvious choice :).
    Panasonic PT-AE4000U projector for movies
    Denon AVR-X3600H pre/pro
    B&W CDM1-SE fronts
    B&W CDM-CNT center
    B&W CDM1 rears on MoPADs
    DUAL NHT SubTwo subwoofers
    Oppo BDP-93 Blu-Ray player
    Belkin PF60 Power Center
    Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
  • jflail2
    jflail2 Posts: 2,868
    edited March 2011
    I just got my dad the Sony 570 model (which has been replaced by the 580.)
    It does 3d as well, and had a built in wireless device as well. Took me about 2 minutes to get it on his network.
    I was surprised at all the features Sony packs in there. Netflix was there, but also Pandora, Slacker, NPR, youtube, and a bunch of other streaming media sources.
    Very very solid player for 150-200, but I'm sure the Oppo is much nicer in the end.
  • jaritta
    jaritta Posts: 277
    edited March 2011
    +1 on the oppo, I have had a little experence with it.....works everytime, extremely fast load time. I beleive the best in the indestry, excluding the ps3. My boss has it and he is a SERIOUS audiofile. He has had problems with failures on several of the onkyo.
    Harman kardon signature 2.1 amp
    Denon 3312
    Epson 8700ub
    Chief mount
    Screen Innovations Performance Series 110in
    Kef q 500 (RL)
    Kef q 200 (C)
    Kef q 800 (Rear RL)
    REL T7 (SUB)
    mx 450 remote
    Sonos-Amp, Connect, Play5
  • BlueFox
    BlueFox Posts: 15,250
    edited March 2011
    I have been using the Oppo BDP83 since July 2009 without any issues. Great picture, and since I have an old AVR that does not decode the new formats, I let the Oppo do it, and then send it to the AVR as PCM. It sounds fantastic. If you want all the latest bells and whistles, get the new Oppo BDP93. It is the same list price as the BDP 83.
