Integra DTR 50.2
Sci-fi Polk Guy
Sci-fi Polk Guy Posts: 194
edited March 2011 in Electronics
Hi guys!! Do any of you own an Integra DTR 50.2? I'd appreciate any feedback about it. Thanks.
Paradigm 11seMkIII mains, w/ Zu Audio jumpers
Paradigm CC 450 center, w/ Zu Audio jumpers
Polk Audio RTi6 surrounds
Paradigm SE sub
Sony BDP S5100 blu-ray player
Panasonic 50" plasma
Yamaha RX A1000 receiver
Parasound HCA 1205A amp
Audioquest Evergreen IC's
Post edited by Sci-fi Polk Guy on
  • TrashyTrucker
    TrashyTrucker Posts: 225
    edited March 2011
    I do and I enjoy it very much. What do you need to know?
    Integra DTR 50.2 used as a preamp
    Rotel RCD 1520 cdp
    AudioQuest Jaguar 72v dbs ic's
    AudioQuest type 8 wire
    biamped to:
    2-Hafler 9500 trans nova's
    AudioQuest NRG-3 power cable's
    dedicated AC line for
    Tesla Plex 20a duplex receptacle
    Panamax Max 7500 pro surge/line conditioner
    SDA SRS 3.1 TL's modded...
    spikes, rdo's, rings, dynamat, sonicaps, mills & aeon
    Panasonic Viera G20 50" plasma
    ...SDA's are just like candy for your ears...
  • Sci-fi Polk Guy
    edited March 2011
    Thanks for the reply. What I want to know how the 50.2 compares to a Yamaha RX-A2000. I'd like to know what you like about the 50.2 and what you might not like about it. Pricewise, the 50.2 is close in price to the Yamaha RX-A2000. Maybe this has already been discussed, but I'd like to know how Integra's Audyssey room correction system compares to Yamaha's YPAO room correction system.
    Paradigm SE sub
    EndersShadow Posts: 17,704
    edited March 2011
    From what I read on AVSFORUM's Audyssey does a much better job that YPAO. Also Audyssey is on other AVR's and is not proprietary to Integra. Its in Denon's, Onkyo's, Marantz and other brands.
    Yamaha's YPAO is limited to only them....
    This link will give you a bit more info on what each version of Audyssey does http://www.audyssey.com/technology/multeq.html
    The Integra has MutliEQ which EQ's the sub as well as all the speakers. Something important to note. Satellites doesn't refer to your surrounds, but all your speakers lol...
    Personally I am waiting till the cost of the MultiEQ XT32 models drop and then getting one of them. Its got more than enough filters for my sub to ensure good sound all around :smile:
