Integra DTR 50.2
Sci-fi Polk Guy
Hi guys!! Do any of you own an Integra DTR 50.2? I'd appreciate any feedback about it. Thanks.
Paradigm 11seMkIII mains, w/ Zu Audio jumpers
Paradigm CC 450 center, w/ Zu Audio jumpers
Polk Audio RTi6 surrounds
Paradigm SE sub
Sony BDP S5100 blu-ray player
Panasonic 50" plasma
Yamaha RX A1000 receiver
Parasound HCA 1205A amp
Audioquest Evergreen IC's
Paradigm SE sub
Post edited by Sci-fi Polk Guy on
Sci-fi Polk Guy wrote: »Hi guys!! Do any of you own an Integra DTR 50.2? I'd appreciate any feedback about it. Thanks.
I do and I enjoy it very much. What do you need to know?Integra DTR 50.2 used as a preamp
Rotel RCD 1520 cdp
AudioQuest Jaguar 72v dbs ic's
AudioQuest type 8 wire
biamped to:
2-Hafler 9500 trans nova's
AudioQuest NRG-3 power cable's
dedicated AC line for
Tesla Plex 20a duplex receptacle
Panamax Max 7500 pro surge/line conditioner
SDA SRS 3.1 TL's modded...
spikes, rdo's, rings, dynamat, sonicaps, mills & aeon
Panasonic Viera G20 50" plasma
...SDA's are just like candy for your ears... -
Thanks for the reply. What I want to know how the 50.2 compares to a Yamaha RX-A2000. I'd like to know what you like about the 50.2 and what you might not like about it. Pricewise, the 50.2 is close in price to the Yamaha RX-A2000. Maybe this has already been discussed, but I'd like to know how Integra's Audyssey room correction system compares to Yamaha's YPAO room correction system.Paradigm 11seMkIII mains, w/ Zu Audio jumpers
Paradigm SE sub
Audioquest Evergreen IC's -
Sci-fi Polk Guy wrote: »Thanks for the reply. What I want to know how the 50.2 compares to a Yamaha RX-A2000. I'd like to know what you like about the 50.2 and what you might not like about it. Pricewise, the 50.2 is close in price to the Yamaha RX-A2000. Maybe this has already been discussed, but I'd like to know how Integra's Audyssey room correction system compares to Yamaha's YPAO room correction system.
From what I read on AVSFORUM's Audyssey does a much better job that YPAO. Also Audyssey is on other AVR's and is not proprietary to Integra. Its in Denon's, Onkyo's, Marantz and other brands.
Yamaha's YPAO is limited to only them....
This link will give you a bit more info on what each version of Audyssey does http://www.audyssey.com/technology/multeq.html
The Integra has MutliEQ which EQ's the sub as well as all the speakers. Something important to note. Satellites doesn't refer to your surrounds, but all your speakers lol...
Personally I am waiting till the cost of the MultiEQ XT32 models drop and then getting one of them. Its got more than enough filters for my sub to ensure good sound all around"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963)
