speakers:couple or decouple
allstock
So, seems we have two schools of thought. Spikes, would seem to "couple" the speaker enclosure to floor. Lots of chat regarding how "spiking" speakers improves everything from bass, to imaging,etc. Vibration control products, vibrapod and the like, would "decouple" the enclosure from the floor. Also lots of chat regarding what an improvement that brings. In other words, doing completely opposite things brings improvement.
Thoughts?
Thoughts?
Two Channel-SDA SRS 1.2tl's,modded, Cambridge Audio 851w amps(2),Cambridge 851e pre, VPI Scout 1.1 tt, Moon audio phono pre,oppo bd105.
HT-Denon avr3808ci,Carver a-753x,Panasonic ae4000 projector,120" screen,ps3,wii console w/full rockband,Panamax conditioner,dbx120 subharmonic synthesizer,jvc dvd-a player, Polk RTi12 mains,Polk CSiA6 centre, Energy ES-18xl sub,two custom 10" powered subs, Def Tech bp2x surrounds(4),Paradigm monitors-rear(2)
Post edited by allstock on
Do spikes really "couple" a speaker to a surface? Essentially, the spikes reduce the amount of direct contact between the two to a minuscule amount. Wouldn't they be truly coupled only if an entire surface of a speaker was in direct contact?
(P.S. I really don't know anything about this... just my random musings.) -
Spike if your speakers are on carpeting. Spikes should be long enough to polk through carpet and pad to the sub-floor. Some (including me) have called this coupling; anchoring may be the better term.
Idea is to eliminate any potential movement of the speaker during play. If they are "floating" on carpet, then movement is possible.More later,
Tour...
Vox Copuli
Try both ways and see what you think...
^ Even if he has hardwood floors... :biggrin:More later,
Tour...
Vox Copuli
Bolt them to the hardwood floor...:biggrin::biggrin::biggrin:
Typo or pun?:biggrin:Spikes should be long enough to polk through carpet and pad to the sub-floor. -
Spikes decouple the speakers from the floor. What you are trying to achieve is to keep the floor from resonating from the speaker cabinet. The tips of the spikes transfer a lot less vibration than the whole bottom of the speaker.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
You don't polk your speakers?~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
Just what I was thinking... seems the word couple might often be used incorrectly, no?Spikes decouple the speakers from the floor. What you are trying to achieve is to keep the floor from resonating from the speaker cabinet. The tips of the spikes transfer a lot less vibration than the whole bottom of the speaker.
I've got some vibration analysis equipment at work, I might bring it home and do some experimenting this weekend.Two Channel-SDA SRS 1.2tl's,modded, Cambridge Audio 851w amps(2),Cambridge 851e pre, VPI Scout 1.1 tt, Moon audio phono pre,oppo bd105.
HT-Denon avr3808ci,Carver a-753x,Panasonic ae4000 projector,120" screen,ps3,wii console w/full rockband,Panamax conditioner,dbx120 subharmonic synthesizer,jvc dvd-a player, Polk RTi12 mains,Polk CSiA6 centre, Energy ES-18xl sub,two custom 10" powered subs, Def Tech bp2x surrounds(4),Paradigm monitors-rear(2) -
Be sure to measure with, and without, a can of Pepsi on top of the speakers. :rolleyes:
http://www.polkaudio.com/forums/showthread.php?t=116201Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
Uh...no...I ain't THAT guy...:biggrin:Two Channel-SDA SRS 1.2tl's,modded, Cambridge Audio 851w amps(2),Cambridge 851e pre, VPI Scout 1.1 tt, Moon audio phono pre,oppo bd105.
From what I understood, the point of spikes was to give your speaker a more solid foundation, so it's less prone to movement because of cone excursion. I use spikes on my LSi25s because they have the side-firing woofer. On the other hand, I use an acoustic pad on my PSW1000 because it doesn't need to be spiked because of the opposing drivers. The pad does help reduce floor vibrations though.
Spikes are also nice for the really tall speakers (e.g. LSi25, bookshelves on stands) to increase their stability. That way they're held up by the hard floor below the carpet. When I first got my 25s, I didn't have the spikes installed yet, and they could easily tilt and tip. Now it's actually quite difficult to get them to move at all.
So, I suppose "couple" or spike with a single driver like the PSW505, where the extra stability is needed, but decouple with a speaker like the PSW1000, where the enclosure's movement will be negated by opposing drivers.- Computer Rig -
YAΘIN MS-20L, polkaudio RT5
- Main Rig -
Pioneer SC-37, Overnight Sensations, Samsung 52" LCD
- Currently In Progress -
Curt Campbell's Uluwatu LCR, LMS Ultra Gjallarhorn, JBL W15GTi stereo subs, 2.1 entertainment system for the gf -
First, my concrete slab doesn't vibrate.
Second, if you were trying to isolate a speaker from floor vibration, a soft carpet is just what you'd want, but that invites movement both I posted about earlier and JimA described above... It's that whole equal and opposite physics thing... AKA Newton's Third Law.
Third, if the floor is vibrating, spikes will not isolate the speaker from the vibration. If anything, by focussing the weight of the speaker into a comparitively miniscule area, and thus coupling the speaker to the floor, vibration transfer is increased.
Think about it... if a bare floor is moving, the only way for the speaker to not move is if it slips...In some recent issues of the audio magazine, ?Hi Fi News? [ref 1], Keith Howard used an accelerometer to measure the levels of vibration in various objects. When he tried measuring the vibrations produced in a loudspeaker stand by playing the speaker he found a result that surprised him. With the speaker unit sitting on cones the level of vibration of the stand was over one hundred times greater than if the cones were replaced with small rubbery feet. This indicates that cones are of doubtful use if the intention is to stop vibrations passing from the speaker to the stand, or to any other solid objects against which the speaker may sit.
Here's the full article link...
http://www.audioholics.com/education/loudspeaker-basics/speaker-spikes-and-cones-2013-what2019s-the-pointMore later,
Tour...
Vox Copuli
