adcom gfa555 for 275?
scottyboy76
There are actually 2 on atlantas cl.
Both same price, have read all the reviews, and comments i can find.
Predictably, they say very good entry level to mid grade, but not the most refined.
I am going from ht rigs to the best 2 channell rig i can slap together on our budget.
I guess the main question is, are the older adcoms still worth a shot from a dependability aspect.
Dont really have the budget to spring for this and get it fixed.
Any help would be appreciated.
humpty dumpty was pushed
Post edited by scottyboy76 on
I have a used GFA 555ll that I've used daily for maybe 3 mos. and it works very well. I also have a 5800 (12yrs) and a 7500 both used that are working just fine but anything can go wrong with older equipment. For $275 I'd buy both and have them reconditioned............but that's me. That's a lot of amp for $275 if it is in good working condition. I personally think the older Adcoms are a step above starter equipment.TO ERR IS HUMAN. TO FORGIVE IS CANINE.
For $275 I'd go for it. I got an Adcom 545 a couple years ago or so for $200 and I've never had any issues with it. As far as I know, the previous owner never had it reconditioned or anything either. These older Adcoms run like tanks.The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
Gfa-555Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
appreciate the input guys, especially bens cryptic message.
the guy is being kind of a jerk.
but theres a nad power tracker 2200, for 200.
not the pe, and there is no mention of upgrade of the relay problems i have read about on old posts here on cp.
wondering, this guy bought this from stereo village, where i used to work, IN THE 80s.
should i expect to have this worked on pretty soon.humpty dumpty was pushed -
Sorry about that. I had technical difficulties with my intro-net. That is a good price for local, and you can test it.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
just read my last post, it sounds like first two sentences are related.
They are not, the cl seller is being a bit of a jerk, not ben, i kinda thought there was some sort of tech problem, such as wife walking in and finding you on that damn site again, you better not be buying something from those yahoo friends of yours again.
something like that cutting short a pos.......................................gotta gohumpty dumpty was pushed -
I've have my gfa55 for about 7months now and no problems what so ever. I bought mine sight unseen from AUDIO Classics for $300 w/ shipping thrown in. The amp can play all day and it doesn't get warm. For$275 I would snatch that up in a hurry.Mine has rack mount front very industrial look.
2-ch---Adcom gfa555>Onkyo P-301>Denon 1940ci-cdp>InfinitySM112s>Sure240pro headphones
H/T>Tosiba au37>Yamaha RX-V665>Denon1940ci-cdp Klipsch set 500>yamaha ysd11dock2chl- Adcom GFA- 555-Onkyo P-3150v pre/amp- JVC-QL-A200 tt- Denon 1940 ci cdp- Adcom GFS-6 -Modded '87 SDA 2Bs - Dynamat Ext.- BH-5- X-Overs VR-3, RDO-194 tweeters, Larry's Rings, Speakon/Neutrik I/C- Cherry stain tops Advent Maestros,Ohm model E
just be careful when buying used Adcom,,, cannot remember the model,but there was some issues with the output transistors which required cleaning/replacement,,Ben can chime in about this.Also, there is an easy tweak which tames some of the brightness that these are known for.Good luck in you quest.JC approves....he told me so. (F-1 nut)
Early model Adcoms are some of the most reliable used amps you can buy.
It was, if I'm not mistaken, only the 565 mono blocks that had leaky caps after a while. The 555 and 545 are fine. I own both.
As far as 'refined' or not, most of that will be determined by your PRE. Get something like an Adcom GFP-750 and see if the 555 is 'refined' or not! Sure it's not going to sound like a 10K amp. But it will sound as good as something two or three times its price.
I hope Ben chimes in, because I also believe they are pretty easy to renew and bring back to original status.
Good Luck....
