PSW-202 is now making a hum when plugged in...
EuroStyle
It seems after reading a ton of posts over the years about powered subs developing a hum, my PSW-202 has joined the club! Out of nowhere last nite, I turned the system on to watch a movie, and there was a loud hum coming from the sub. It is not effected by unplugging the source cable, and only goes away when the sub is actually switched to off. After reading, it seems they all have the same issue, mine just lasted a lot longer then most. It stills plays audio, and the hum, but I unplugged it as to not damage the driver. I called to get the repair info, but I guess I am going to be subless for a while as I have to save the money to send it in. Being laid off, I have actually had a bit more time to catch up on movies, but I guess now they'll be subless..... :frown:
Sean
Sean
Post edited by EuroStyle on
A loud hum is probably just a bad power supply cap. How handy are you with a screwdriver and soldering iron?Turntable: Empire 208
Arm: Rega 300
Cart: Shelter 501 III
Phono Pre: dsachs consulting
Digital: Marantz SACD 30n
Pre: Conrad Johnson ET3 SE
