Subwoofer
over50
I need advise from the polk forum . I want to either replaCE MY 505 with a better sub ,like SVS ,Velodyne or i reaaly like the Epik legend. Or should i by another 505 and have a 6.2 system. My room is approx 12x20, i mainly use for HT and Music. I was very close to buying a used Velodyne or a Polk 8" 2000 .The 2000 look nice but i didnt think replacing my 12" 505 with a 8" woulnd be better. The last minute i changed my mind .Please give options ?
Marantz SR 7007
polkaudio RTi10
polkaudio CSi A6
polkaudio RTiA3
B&K ST.3140 Power Amplifier
HSU Research VTF2 MK3
Vizio P65-C1
Panasonic 605 blu ray
Onkyo DS-A4 i-pod Dock
Universal Remote
BDI Icon 9429 TV Stand
polkaudio RTi10
polkaudio CSi A6
polkaudio RTiA3
Vizio P65-C1
Universal Remote
Post edited by over50 on
IMHO, the downsizing of the sub isn't really that big of a concern. While the 505 is a solid sub, the 2000 is a totally different class of sub, and eventhough it may have been a lot smaller the 2000 has a continuous output of 1200W, whereas the 505's is 300W. The 2000 has a Dynamic output of 2400W, and the 505's is 460W. The overall frequency range for the 2000 is 22-200Hz, and the 505's is 23-160Hz. By the numbers the 2000 is a superior sub to the 505, regardless to it's size, IMHO. SVS, Velo, and Epik are all very good choices when it comes to subs, some of the best in the business are made by those companies. It is all up to you and your budget, you can easily spend more than your entire HT just on a "quality sub" alone. It's the main reason why I have never listened to another sub besides my PSW125 for too long, because it will make me want to go out and buy something better, lol. Adding another 505 is an option for you, like I said, it is a quality sub for the price. It is sometimes tough to get 2 subs, even if identical, situated properly and to play nice with one another, but def. an option. Some of the more experienced Sub guys will chime in I'm sure, just be prepared to open up the wallet for what you may be asking for, lol. Good luck.
-JeffHT Rig
Receiver- Onkyo TX-SR806
Mains- Polk Audio Monitor 70
Center- Polk Audio CS2
Sub- Polk Audio PSW125
Blu-Ray- 80 GB PS3
2 CH rig (in progress)
Thanks for the reply. You put my thoughts into words. You summerized my situation. The more i lok ,the more questions i have. The polk 2000 was a good deal, the seller wanted 275... that seems to be a good price. about half off .Marantz SR 7007
polkaudio RTi10
polkaudio CSi A6
polkaudio RTiA3
Vizio P65-C1
Universal Remote
BDI Icon 9429 TV Stand -
That's the funny thing about hindsight, it is always 20/20, lol. What may not have seemed like a good idea at the time, always seems better when you look back at it later. Gather up as much information as you can by doing research, looking at reviews, listening to the advice here, and testing a few out if possible. In the end it will all come down to funds available, and what you can get your hands on that you will be happy with. The guys here won't steer you wrong, good luck.
-JeffHT Rig
Blu-Ray- 80 GB PS3
Question. If i bought the Polk 2000 and kept my 505. Would keeping both sub be a bad idea. I just check the craigs list and the seller drop the price. Just thinking out loud. I klove the bass ,if i wasnt married i`d set the sub so the windows would rattle. Any thoughts on the different subs.Marantz SR 7007
polkaudio RTi10
polkaudio CSi A6
polkaudio RTiA3
Vizio P65-C1
Universal Remote
Good advise. It all comes down to money. I could buy the 2000 and start saving to replace the M70 with RTai9. Thats my long term set up.Marantz SR 7007
polkaudio RTi10
polkaudio CSi A6
polkaudio RTiA3
Vizio P65-C1
Universal Remote
When running more than one sub, it is "ideal" to have them be pretty close to the same. Is it impossible to setup two different subs? No, but it can be difficult to get them to play nice with eachother, but it can be done. If you can spare the cash, and the time to fiddle around with getting the 2000 to integrate with your system, it is an option for you. So is saving up the cash and buying a sub that will outperform those two subs combined. Hopefully someone else will chime in soon with some more guidance.
-JeffHT Rig
Blu-Ray- 80 GB PS3
If the dsw 2000 and 505 dont sound good together , i could sell the 505 and keep the better dsw. Also when i replace the fronts with the Rt the Recommended Subwoofers
are the dsw line. Just too many choice`s ..Marantz SR 7007
polkaudio RTi10
polkaudio CSi A6
polkaudio RTiA3
Vizio P65-C1
Universal Remote
That is also an option that I forgot to mention in my last post, I see you have your wrapped around this pretty well. Try not to pull your hair out over this, but it can be a nerve racking ordeal, esp. when we are talking about your hard earned money, lol.
-JeffHT Rig
Blu-Ray- 80 GB PS3
After looking closer at the dsw line. is the micro pro 2000 better the the pro 600. The 600 is a 12" vs 2000 is a 8" ..any thoughts.Marantz SR 7007
polkaudio RTi10
polkaudio CSi A6
polkaudio RTiA3
Vizio P65-C1
Universal Remote
Again, two much different subs. I would give the nod to the MicroPro still, but that is my unproffesional opinion.
-JeffHT Rig
Blu-Ray- 80 GB PS3
Thanks for your input.Marantz SR 7007
polkaudio RTi10
polkaudio CSi A6
polkaudio RTiA3
Vizio P65-C1
Universal Remote
Going to pick up the polk 2000.Marantz SR 7007
polkaudio RTi10
polkaudio CSi A6
polkaudio RTiA3
Vizio P65-C1
Universal Remote
+1 about difficulty getting different subs to play nice. I had to tweak a LOT to get my LSi25s' subs and PSW1000 to integrate well together, and even then I know one solid sub would be better than their combination. Congrats on picking up the MP2k though. That's a mighty little sucker! If you end up not liking it, or decide to upgrade even moreso, there are plenty of guys around here who would take it off your hands.
Cheers!- Computer Rig -
YAΘIN MS-20L, polkaudio RT5
- Main Rig -
Pioneer SC-37, Overnight Sensations, Samsung 52" LCD
- Currently In Progress -
Curt Campbell's Uluwatu LCR, LMS Ultra Gjallarhorn, JBL W15GTi stereo subs, 2.1 entertainment system for the gf -
Jim is right, that 2000 is a really good sub, esp. for the price. Congrats on getting it and let us know how it works out. You may just end up running that one and not needing your 505 anymore, lol.
-JeffHT Rig
Blu-Ray- 80 GB PS3
Bought the DSW2000. Looks nice, has a much more clear deeper sounding bass then the 505. Its lots smaller then the 505 seems to be much more power. still playing aorund with the settlings. I think LOTR would be a good dvd to test the bass. Ended up paying $250.00.. I think thats a good price, the sub is less then a year old, came with all the parts, micr,remote,manual,box.Marantz SR 7007
polkaudio RTi10
polkaudio CSi A6
polkaudio RTiA3
Vizio P65-C1
Universal Remote
Excellent, good snag. I figured you would be impressed with it, it is a good sub, regardless of it's size. Keep us posted on your findings and what you decide to do about having 2 subs or just keeping the 2000.
-JeffHT Rig
Blu-Ray- 80 GB PS3
I`ve got the DSw2000 aLL SET working fine.I made a Good choice, thanks to the advise in this form. I`m very happy with the sound and this is a real nice subwoofer. Sounds good with my other Polk speakers.My future plan is to replace everything with the Rt seriers. I`m now halfway there.I just sold my 505. I didnt see any advantage trying to use both the sub`s.Marantz SR 7007
polkaudio RTi10
polkaudio CSi A6
polkaudio RTiA3
Vizio P65-C1
Universal Remote
Just bought RtiA5 and now have the same series. I had doughts aabout timbre matching.All the post are right, it does matter and does sound better . Having the fronts and center match i can hear sounds traveling from fronts to the center speaker. I really like the new rt speakers. The DSW i spend most of my time turning down the volunm. Thanks to the wife.. Will see what i can buy closer to black friday. Maybe power amplifier.Marantz SR 7007
polkaudio RTi10
polkaudio CSi A6
polkaudio RTiA3
Vizio P65-C1
Universal Remote
