Center/surround bars
Only have about 5inch height available. Are there any decent centers like a surround bar?
Marantz 1607 - Polk S60 - S35 - Emotiva XPA-3 - Polk DSWPRO550wi
This LCR bar can be used as a center channel; http://www.parts-express.com/pe/showdetl.cfm?Partnumber=300-684
Here is a better quality product from Pinnacle speakers; http://www.4electronicwarehouse.com/products/pinnacle-speakers/qp7-3-channel-lcr-speakers.html?id=&utm_source=thefind&utm_term=qp-7%20spkr%20bar&utm_campaign=pinnacle-speakers&utm_medium=comparisonDARE TO SOAR:
Hum, DELL has decent pricing on the Pinnacle bar; http://accessories.dell.com/sna/products/Accessories/productdetail.aspx?c=ca&l=en&cs=cadhs1&sku=A3875325&baynote_bnrank=2&baynote_irrank=0&~ck=baynoteSearchDARE TO SOAR:
Vm20 Rec rm vm30 micro pro 3000 akai 2 channel. ht anthem MTX 5 channel anthem P2 statement anthem 325, 8 channel Martin Logan power amp for 4 ceiling ls900 2 and outdoor polks, 2 JL 110’s subs panasonic 65" plasma lsim 705’s , 706c, L200 and Control 4 garage rig monitor 10s crossovers by VR3, dynamat, RDO-194's, new drivers. psw 111 Pioneer 9040 BDP53fd 100 " screen Nakamichi HD projector, and Panasonic 65” plasma. -
i just need the center. Would it be a waste if that speaker has a right left channels also?
How does that work?
Can you buy the center separate on the Vm20?Marantz 1607 - Polk S60 - S35 - Emotiva XPA-3 - Polk DSWPRO550wi -
You just connect all of the LCR speakers to be used as a center.i just need the center. Would it be a waste if that speaker has a right left channels also?
How does that work?
Ah! I was in the impression you wanted a larger center (you have mentioned like a surround bar). Yes, the VM20 can be used as a center an can be bought single however, be carefull of the price you pay for as Polk sells it single for 500 on their site and sells pair for 500 at Polk Direct. IMO, 500 for those speakers is inflated and not worth that money. You have to pay much cheaper than that to be worthwhile. http://checkout.polkaudio.com/basket.asp http://stores.ebay.com/Polk-Audio-Direct/_i.html?_nkw=vm20&submit=Search&_sid=686154689
IMO, this http://accessories.dell.com/sna/products/Accessories/productdetail.aspx?c=ca&l=en&cs=cadhs1&sku=A3875325&baynote_bnrank=2&baynote_irrank=0&~ck=baynoteSearch is a much better investment and for less coins.DARE TO SOAR:
never mind on my vm20 comment. I was thinking they were reg, sized speakers.
i mentioned surround bars because some where thin enough for my setup.Marantz 1607 - Polk S60 - S35 - Emotiva XPA-3 - Polk DSWPRO550wi
