Another Setup Question
jhumur
Hi, after 2 months I'm still tweaking my AV setup. It's comprised of a Pioneer VSX-1120-k receiver, a pair of Monitor 60 Series 2 (bi-amped), and a PSW10 sub. The AVR manual said that if the speakers are THX certified then to set the speakers to "small" in the setup menu before running the auto-calibration (MCACC.) Otherwise to leave the speaker size to large. I set the speakers to small (i.e. THX certified) before running the calibration. Did I do the right thing? Are my speakers THX certified? I tried to find out from the Polk website, but didn't get anything.
P.S. You'll see the same question at the bottom of my previous post. That was totally unintentional. Sorry!
Manually set the crossover points for all the speakers to 80hz. Get rid of the bi-amp crap and run it normally. Go to Radio Shack and get an SPL meter. I like the digital one. Set the levels manually. Set the distances manually with a tape measure. Don't use the auto setup.
Enjoy
Ben -
I agree with Ben on this one, I ran the auto setup on my Onkyo and it gave me a place to start, then I tweeked it from there to get it where I wanted it. +1 on losing the Bi-Amp, you aren't really gaining anything from it, since the AVR gets it's power from the same amp, and simply adding another set of speaker wire isn't going to increase any power going to them. Some people swear by it, but I tried it on my Monitor 70's and it actually sounded a bit worse to me, YMMV though. 80 Hz is the "THX" setting you are looking for, but I wouldn't put much stock in that, with speakers like the Monitor series, you probably wouldn't notice much difference between THX, and not anyway. The THX certification is more for your AVR than the speakers, and IMHO isn't really that big of a deal, if it sounds good, why worry if it is "THX certified" or not. Hope this helps.
-JeffHT Rig
Receiver- Onkyo TX-SR806
Mains- Polk Audio Monitor 70
Center- Polk Audio CS2
Sub- Polk Audio PSW125
Blu-Ray- 80 GB PS3
2 CH rig (in progress)
Thanks guys! I guess, I was just wondering if I should set the speaker size in the AVR setup to SMALL or LARGE. Or, doesn't it really matter?
Small, because you should be sending all bass under 80hz to the subwoofer.Main Surround -
