The "3 foot from the side wall" rule for SDAs.
Six to eight inches off the back wall is pretty much the norm for SDA's.
Placing yours in the nooks is basically corner loading.
Yeah, after hearing them just backed up to the nooks, I think placing them inside would be a bad idea. Sometimes you just have to throw ideas out there though...Or Just sell them
Not a chance! Even if I couldn't play them, I'd keep them just for looking at! :biggrin: -
I sense some LSI-25's in your future....The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
TOOLFORLIFEFAN wrote: »Alan,
I would not do that. If I was you I would go with room treatments, and for gods sake SPIKE them, get them off the floor..
IMO rooms that are not that ideal for SDA's room treatments are the only thing to help balance the sound..
Just my .02
What do you mean by Room Treatments?
I have a similar issue. I have one side wall and speaker is too close to that. I am definitely hearing that speaker more and not getting the SDA effect as a result. Do you mean room equalization? I have a B&K ref 50 that has room equalization but I can't seem to make heads or tails of what it does.
I too am contemplating buying a new house as a result. FYI- SDA 1C'sI got static in my head
The reflected sound of everything -
something like this http://www.sweetwater.com/shop/studio/acoustic-treatment/buying-guide.php but there are many nice panels out there, some more expensive then others..
Don't think the wife would like this in our living room. How about room equalization?I got static in my head
Room equalization tries to solve a different issue (room modes increasing/decreasing the response of certain frequencies). You could try simply decreasing the level of the loud speaker, either through a fade knob or at your source, but I have my doubts as to the effectiveness of that route.
TOOLFORLIFEFAN wrote: »something like this http://www.sweetwater.com/shop/studio/acoustic-treatment/buying-guide.php but there are many nice panels out there, some more expensive then others..
Glue on foam costs a bit less, but is not normally very effective. Check out realtraps.com or gikacoustics.com.VTL ST50 w/mods / RCA6L6GC / TlfnknECC801S
Conrad Johnson PV-5 w/mods
MF x-DAC V8, HAInfo NG27
NAD SS rigs w/mods
GIK panels -
I wish I could help, but all I have to add is those things are monsters. They look incredible.
Does anyone have a link where I can read more about them? I'm very curious about how much they weight.Receiver: ONKYO 709
Amplifier: Acurus A200x3
Front: EmpTek E55Ti
Center: EmpTek E56Ci
Surround: EmpTek E5Bi
Sub: Elemental Designs A5-350
TV: LG 55"
Blu-Ray: PS3 -
So.....along these lines, how exactly would a person "treat" the side reflections when the speakers are too close to the sides? Would you place the treatment against the side wall and very near to the speakers(say 1-3 feet forward)? Or further forward in the room?
Is there any reason to treat/not treat the reflections behind speakers? I have yet to see anyone treating behind their screen or mains/center. Theories? Not enough of a problem to notice much difference? Would it kill the sense of depth? -
TO Kawizx9r, Dude you have a Really nice rig. I am truely impressed. If you could tell me what are those speakers and around what do they go for.IF someone like me w/ my Adcom gfa55 be enough to push those mountains. Very nice .....LW2chl- Adcom GFA- 555-Onkyo P-3150v pre/amp- JVC-QL-A200 tt- Denon 1940 ci cdp- Adcom GFS-6 -Modded '87 SDA 2Bs - Dynamat Ext.- BH-5- X-Overs VR-3, RDO-194 tweeters, Larry's Rings, Speakon/Neutrik I/C- Cherry stain tops Advent Maestros,Ohm model E
