polk rtia9
Thinking.if i should upgrade the a7s to.the a9s....would thexpa3 be enough.or do i need the xpa2?! Would the diffrence be noticeble would be my last upgrade very pleased with the a7s but was just wondering?!
Room Theater:
Fronts:RTIA3
center; CSIA6
AVR: Onkyo 709
panasonic 55"plasma
Ps3 slim 250gb
surrounds.Fxia6
Sub...svs pc13 ULTRA
Amp:Emotiva xpa3
Fronts:RTIA3
center; CSIA6
AVR: Onkyo 709
panasonic 55"plasma
Ps3 slim 250gb
surrounds.Fxia6
Amp:Emotiva xpa3
The xpa's 200 watts would be plenty.
So my current emo would be fine?!Room Theater:
Fronts:RTIA3
center; CSIA6
AVR: Onkyo 709
panasonic 55"plasma
Ps3 slim 250gb
surrounds.Fxia6
Amp:Emotiva xpa3 -
bumpRoom Theater:
Fronts:RTIA3
center; CSIA6
AVR: Onkyo 709
panasonic 55"plasma
Ps3 slim 250gb
surrounds.Fxia6
Amp:Emotiva xpa3 -
Power wise it should be fine.Main Surround -
Den - Rotel RSP-1068 / Threshold CAS-2 / Boston VR-M60 / BDP-05FD -
It all depends on how good of a deal you can get for the A9's. I liked the a9's much better, from top to bottom. Also look at the lsi 15's, I've seen them lately go for around $800 and is also a step up from the A7's.
Im more into home theater with the rtia would the lsi15 be better?! And the rtia9 would have enough bass at 200wpc?!Room Theater:
Fronts:RTIA3
center; CSIA6
AVR: Onkyo 709
panasonic 55"plasma
Ps3 slim 250gb
surrounds.Fxia6
Amp:Emotiva xpa3 -
I don't think changing your front speakers is going to make a drastic change in your HT experience. You already have a very nice setup. If music was your main concern, then maybe. In HT, though, I'd look elsewhere in your system if you've got a real upgrade bug.
I would upgrade the sub with the extra coin. An SVS would be worlds more of low end for ya.HT SYSTEM-
