DSW PRO Front Firing
kevhed72
kevhed72 Posts: 5,165
Who has done this...and what did you think?
AND, where did you find a sub cable to fit under there?
Post edited by kevhed72 on
  • Erik Tracy
    Erik Tracy Posts: 4,673
    edited March 2011
    kevhed72 wrote: »
    You could always get a right angle rca adaptor, or rotate the sub so the back panel connectors are not on the bottom.
    I say go for it and tell us what you think!
  • MCCOBRA
    MCCOBRA Posts: 68
    edited March 2011
    been wondering on this also. i have mine downfiring on carpet..... wish i had wood floors
    My setup:
    58" Samsung C7000 plasma
    Pioneer VSX 1120-k
    Sony BDP 770 b-ray
    ROTEL RMB 1095
    ROTEL RB 1090
    Black Mamba II intc.
    RTi A9 (pair)
    CSi A6
    FXi A6 (pair)
    DSW PRO 550wi
    :biggrin::biggrin:
  • greg2350
    greg2350 Posts: 544
    edited March 2011
    I have done it with tile floor liked it better downfiring sounded better on the lower frequinces, but I didnt play with placing much with front firing. Sub seemed weeker front firing found myself turning the volume up more on the sub and yes had to use a right angle cable:smile:
    TV: Philips 42" LCD 1080p
    Front Speakers: Polk Audio RT800i
    Center Speaker: Polk Audio CS1
    Surround Speakers: Polk Audio R50's powered of Denon AVR
    Subwoofer: Polk Audio DSW pro500
    AVR: Denon 3801
    DVD Player: Denon DVM 745 upscale 1080p
    Sat: Directtv HD 10
    Front Speakers Amp: Rotel RB 890
    Center Speaker amp: Rotel 970 BX
