Anybody using vinyl laminate flooring?
ROHfan
ROHfan Posts: 1,014
edited March 2011 in The Clubhouse
We're gonna be re-doing the LR and the laminate is a very inexpensive option and looks real nice. I don't have the cash to go for the high quality solid hardwood so I'm looking at options. A friend of mine loves his and the laminates seem to get some good reviews on the internet. Depending upon the brand I hear that they're extremely durable, in some cases more so than real wood. Any opinions?
TV: 65" Samsung QLED 4K
AIYIMA Tube T7 preamp --- Nobsound 12AX7 tube preamplifier
Post edited by ROHfan on
  • kevhed72
    kevhed72 Posts: 5,142
    edited March 2011
    Do you mean like Pergo flooring, or actual vinyl....
  • cubdog
    cubdog Posts: 835
    edited March 2011
    Probably a good option if you have large dogs. Our Dane and Lab really tore up our wood floors at our last house. I think the laminates are much better and nicer looking than they used to be.
    cubdog
    Shuguang Classic S8MK
    Emotiva XDA-2
    Bel Canto M300 mono blocks
    Bel Canto DAC 1.5
    Squeezebox Touch
    Sony SS-M7
    A/D/S L710
  • polrbehr
    polrbehr Posts: 2,842
    edited March 2011
    Did our BR last year with Estate Cherry laminate (clearance at HomeD, I think it was $.89 sq. ft?).
    Piece of cake to install, and looks as good as the day we put it in.
    Two things if you go the DIY route - stagger your joints (I know, you will lose some to waste... do it anyway) like you would for a hardwood install. It's just every other row, it will not amount to much and it's cheap enough anyway.
    Do all your cutting outside. The dust from that stuff is extremely fine (and slippery), and will get onto everything.
  • codyc1ark
    codyc1ark Posts: 2,538
    edited March 2011
    I helped the fiancee's sister do her hallway and bedroom with this last year, as polrbehr states, stagger your joints, and you shouldn't have any issues. Great product, easy to use. SHE did skimp and find the cheepest she could, and we had just a few issues with fit here and there, but nothing an razor blade didn't take care of. Good luck!
  • blueboxer
    blueboxer Posts: 621
    edited March 2011
    Laminate is a good option for high traffic homes or homes with large animals. I went with walnut floors, it has held up well to two large and high energy dogs, but there are scratches to either fill or refinish from time to time. I went with a distressed wood, so when I see a scratch I use a black filler and it just adds to the look. If that is something that will drive you crazy laminate is a great option. There is also some porcelain tile that looks like wood that I have seen and really liked. Lumbarliquidators is a great site to use as well.
  • ROHfan
    ROHfan Posts: 1,014
    edited March 2011
    Thanks for the replies. I'm going to Disney next week and when I get back I plan on starting. Will probably do so skim coating on the walls, paint them, then do the floor. I'll be adding a new TV stand/audio center and some new Polk in-walls for the surrounds and keep the M60 fronts and upgrade to a CS2 center. Then we add the big LED TV soon after. We'll probably spend a lot more time watching movies which is a good thing considering I'll be broke after the remodeling!
  • ROHfan
    ROHfan Posts: 1,014
    edited March 2011
    kevhed72 wrote: »
    Yeah, like Pergo or Harmonics.
  • blueboxer
    edited March 2011
    Is this on a first floor or second floor?
  • ROHfan
    ROHfan Posts: 1,014
    edited March 2011
    blueboxer wrote: »
    First (and only) floor, main entrance, high traffic. No dogs, but two kitties.
  • dee1949
    dee1949 Posts: 1,425
    edited March 2011
    ...about staggering the joints...the piece you cut to end one row...you use the remainder to start next row. Leave 1/4" between baseboard and use shoe molding to cover gap...for expansion and contraction. if it is going on concrete they provide a roll of vinyl to lay down first. The floor floats on top. Vapor barrier and prevents squeaks.
