subwoofer options help.
ohskigod
ohskigod Posts: 6,505
while i am happy with the results of modifing my sony wm500 (mod podge, poly fill, placed on a marble slab), i am looking at different options for a new subwoofer. budget is sub 400.00 ish
here are the options i am looking at
1) SVS CS series, i have an onkyo m501 150x2 i can power it with, i assume, i can only power with 150 watts from one channel since it can not be bridged.
2) HSU VTF 2, 399.00 was the price i think?
3)Dayton Titanic/Vance Dickason kit, 349.00 shipped
4) Adire Rava (a little over budget, but not bad 399.99 plus shipping)
5) Another Sony WM500 and run both stacked would be best i assume. is this the best cost to performance option?
i'm looking for opinions so i can make a better informed decision. all you guru's please chime in. am i missing any other options?
I thank you in advance for your help.
P.S. the room is fairly large, i dont have dimensions,but figure about 14' by 20' (open air into the dining room) with 10' cieling (ish).
Living Room 2 Channel -
Upstairs 2 Channel Rig -
Post edited by ohskigod on
  • gatemplin
    gatemplin Posts: 1,595
    edited February 2004
    I was in your postion about a year ago. I had a modded sawm500. I foolishly bought another because I could get a good discount. I have since given them away.
    My choices of the list would be 2 through 4. If you can build your own box I would recommend the Adire Shiva or Tempest and use each channel of the Onkyo for each 8 Ohm VC.
    Graham
  • goingganzo
    goingganzo Posts: 2,793
    or look at av12 or 15 bad to the bone if you get these you will never look back
  • PolkThug
    PolkThug Posts: 7,532
    The Velodyne CHT15 went on sale again at CC for 499.
  • ohskigod
    what is an "av12 or 15"? :confused:
  • ohskigod
    did a search, and they seem to be drivers. can i get plans for any of these projects? would like to look at them and make sure i can undertake the task. I'm definitly a beginner at the DIY thing.
    P.S. thanks for the help to all in case i forget to thank you later.
  • gatemplin
    The AV12 and 15 are sub drivers from www.stryke.com . They are very popular and I am sure you can find plenty of examples of different projects on the net.
    Graham
  • ohskigod
    after some thought, im toying with getting a driver with dual 8 ohm voice coils (will go best with the onkyo m501 amp i have 150w x 2, which can not be bridged). the shiva looks like a great choice. i will have to go with a kit for the enclosure, since my woodworking skills are marginal at best. i was thinking
    a) adire audio shiva (apparently on backorder)
    b) would this driver work if i decided to go 15 inches http://www.partsexpress.com/pe/pshowdetl.cfm?&PartNumber=295-190&DID=7
    this coupled with the following enclosure kit.
    http://www.partsexpress.com/pe/pshowdetl.cfm?&DID=7&Partnumber=300-729
    any input or thoughts would help me avoid costly errors, which would be greatly appreciated. thanx for the help in advance.
    the strykes did look like they kick ****, but the low impedance would not be a good match for the amp i will be using.
  • goingganzo
    sono tube if you can cut a circl you can make a sub. also whar you save on the encloser you can get a good saw also the av15 will devestqate the other subs unless you get a tempest or a tintanic mk3 15in with will allmost hang. but go big or go home.
  • dorokusai
    dorokusai Posts: 25,638
    I am a plug-n-play individual, and would choose the HSU. I could make a subwoofer that doubled as bunk bed, but man, I have beer to drink.
    The aforementioned DIY designs are well proven and great performers. There is a huge amount of satisfaction in a completed, working project. You will need some more power to get into the "devastating" category. I am with GG on the go big statement, no doubt.
  • gatemplin
    Kyle sells numerous kits for Adire and Stryke drivers at http://acoustic-visions.com/~acoustic/products/subwoofers/enclosures/ . The Shiva kit starts at $330 with driver and amp. You could also take the designs from Adires website and get someone to cut it for you.
    Graham
  • Early B.
    Early B. Posts: 7,900
    Go with the Hsu STF-2.
    "God grooves with tubes."
  • ohskigod
    the stf-2 is the one you can get at comp usa right?
    is it a good sub? its 10" and am wondering if that would perform beter than the modded wm500 sony i have now. i here good things about the HSU but never heard it. maybe a demo might be in order.
    if this is the sub i am thinking about, isnt it almost exactly like the vtf-2? with subtle differences. i hear goo dand bad things, the bad sems to be related to not being able to properly demo the stf-2 in a place like Comp USA. i believe it is 349.00 their? this does seem to be a valid option. The DIY option would be a complete no brainer if i had any woodworking skill :D
  • POLKOHOLIC
    POLKOHOLIC Posts: 407
    Make a note of the Foam surrounds on that driver. Look at this instead:Sub
  • Dr. Spec
    Dr. Spec Posts: 3,780
    The STF-2 is equal to a VTF-2 in maximum extension mode.
    I owned an STF-2 for a week. Nice build quality and cabinet finish. Sounded really fine on music at moderate volumes.
    Can't handle HT at more than about -20RL calibrated about 3 dB hot. At -15RL, it compressed badly and soft bottomed so I backed off right away. This is in a 2000 ft3 room 12 feet from the sub corner loaded.
    I can recommend this sub in a small room for music applications. I can't recommend it for HT in moderate to larger rooms - it simply can't move enough air.
    If HT is important to you and you want to stay with Hsu as an option, I recommend the STF-3 or the VTF-3 Mk II. That driver can move about 3.5 times as much air as the STF-2 (10" 8mm xMax vs. 12" 18 mm xMax) and will do a lot better on HT.
    SVS
  • goingganzo
    edited March 2004
    look for a kit from struke if you can screw in a few screws you can buld the sub
