CS400i And Five Way Binding Posts
Got Some monster banana connectors for my speakers. I was wondering how to connect them to the center(CS400i). There is no hole on the end of the binding post for the banana. I thought that they were 5-way. Am I suppose to pop the little plastic end piece off of the of the binding post? Just wanted to know before I break something.
Post edited by del44 on
grab a butter knife and pop out the little black plastic piece in the binding post. its there because of issues in europe. dont worry about saving them. then you can use the banannas
Unscrew the caps from the binding post, they fall right out.
Take the cap and place it back on and screw it back on. Simple- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
We had one guy a few years ago actually drill out the posts.....
No, it wasn't me.
DRILL?
Are you for real?
I could imagine that, Russ...laughing wildly...pressing in the trigger, the reving drill, muahahahhaha! hahahaha! Funny stuff!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
I was hoping it would be that easy. Thanks.:D Just think, I was just about ready to get the drill out. whew!
Flat-head screwdriver works, too.
Two Channel Setup:
Speakers: Wharfedale Opus 2-3
Integrated Amp: Krell S-300i
DAC: Arcam irDac
Source: iMac
Remote Control: iPad Mini
3.2 Home Theater Setup:
Fronts: Klipsch RP-160M
Center: Klipsch RP-160M
Subwoofer: SVS PB12NSD (X 2)
AVR: Yamaha Aventage RX-A2030
Blu Ray: Sony BDP-S790
TV Source: DirecTV Genie -
I used my little finger nails to pull them off!
Panasonic TH-50PX80U Plasma HDTV
Polk Audio RT800i (fronts)
Polk Audio CS400i (center)
Polk Audio F/X1000 (side surrounds)
Polk Audio RTi6 (back surrrounds)
Velodyne CHT-15 (subwoofer)
Yamaha RX-V1400 (Pre/Pro)
NAD C272 (2-ch Amp)
Adcom GFA-7605 (5-ch Amp)
Toshiba SD-3109 (DVD/CD player)
Malata DVP-580 (Multi-region DVD player) -
if you use your drill.. make sure you wear safety goggles.. i did.
lay your speaker on the floor. plug in the drill. straddle the speaker.. and with a gentle yet firm pressure. apply the drill at high speed to the little plastic cap.. continue till it's all ground up.. works great.
PolkFest 2012, who's going>?
Sounds great. The only bit I have is a 3/4 inch. Will that do the trick? I do have a big vise though. It should hold the speaker really good. I sure don't want that big sucker to get away from me.
you so crazy... lol
3/4 inch is to big..
