CS400i And Five Way Binding Posts
del44
del44 Posts: 686
edited February 2004 in Speakers
Got Some monster banana connectors for my speakers. I was wondering how to connect them to the center(CS400i). There is no hole on the end of the binding post for the banana. I thought that they were 5-way. Am I suppose to pop the little plastic end piece off of the of the binding post? Just wanted to know before I break something.
Post edited by del44 on
  • Airplay355
    Airplay355 Posts: 4,298
    grab a butter knife and pop out the little black plastic piece in the binding post. its there because of issues in europe. dont worry about saving them. then you can use the banannas
    VR3 Posts: 29,398
    Unscrew the caps from the binding post, they fall right out.
    Take the cap and place it back on and screw it back on. Simple
  • TroyD
    TroyD Posts: 13,124
    We had one guy a few years ago actually drill out the posts.....
    No, it wasn't me.
    BDT
    VR3 Posts: 29,398
    DRILL?
    Are you for real?
    I could imagine that, Russ...laughing wildly...pressing in the trigger, the reving drill, muahahahhaha! hahahaha! Funny stuff!
  • del44
    del44 Posts: 686
    I was hoping it would be that easy. Thanks.:D Just think, I was just about ready to get the drill out. whew!
  • Loud & Clear
    Loud & Clear Posts: 1,538
    Flat-head screwdriver works, too.
    Two Channel Setup:
    Speakers: Wharfedale Opus 2-3
    Integrated Amp: Krell S-300i
    DAC: Arcam irDac
    Source: iMac
    Remote Control: iPad Mini
    3.2 Home Theater Setup:
    Fronts: Klipsch RP-160M
    Center: Klipsch RP-160M
    Subwoofer: SVS PB12NSD (X 2)
    AVR: Yamaha Aventage RX-A2030
    Blu Ray: Sony BDP-S790
    TV Source: DirecTV Genie
  • hamzahsh
    hamzahsh Posts: 439
    I used my little finger nails to pull them off! :D
    Panasonic TH-50PX80U Plasma HDTV
    Polk Audio RT800i (fronts)
    Polk Audio CS400i (center)
    Polk Audio F/X1000 (side surrounds)
    Polk Audio RTi6 (back surrrounds)
    Velodyne CHT-15 (subwoofer)
    Yamaha RX-V1400 (Pre/Pro)
    NAD C272 (2-ch Amp)
    Adcom GFA-7605 (5-ch Amp)
    Toshiba SD-3109 (DVD/CD player)
    Malata DVP-580 (Multi-region DVD player)
  • danger boy
    danger boy Posts: 15,722
    if you use your drill.. make sure you wear safety goggles.. i did. :D
    lay your speaker on the floor. plug in the drill. straddle the speaker.. and with a gentle yet firm pressure. apply the drill at high speed to the little plastic cap.. continue till it's all ground up.. works great.
    :p
    PolkFest 2012, who's going>?
  • del44
    del44 Posts: 686
    Sounds great. The only bit I have is a 3/4 inch. Will that do the trick? I do have a big vise though. It should hold the speaker really good. I sure don't want that big sucker to get away from me.
  • danger boy
    you so crazy... lol
    3/4 inch is to big.. ;)
  • HBombToo
    HBombToo Posts: 5,256
    i read jolly rogers also:eek:
    ***WAREMTAE***
