Carver TFM 24 or 25 junk/parts unit
nguyendot
My TFM 25 has a bad input board (I think).
Looking for a TFM unit with the same RCA input board. If you have a junk unit or this piece alone, I would appreciate it.
The left channel is completely distorted, right channel is fine. Goes into protect if you turn it past 10%.
What's odd is if I swap the leads on the input board, the problem follows the channel of the board. I tested both sides of the amp and both channels work free and clear with the right channel of the input board.
I really don't want to spend $300+ to have it repaired when I know its something simple.
Main Surround -
Post edited by nguyendot on
The TFM-25 was notorious for bad solder joints. especially around the transistors due to heat build up. Look the boards over closely.>
>This message has been scanned by the NSA and found to be free of harmful intent.< -
I had the entire input board desoldered and resoldered, with new transistors too! I don't know what gives
Main Surround -
Den - Rotel RSP-1068 / Threshold CAS-2 / Boston VR-M60 / BDP-05FD -
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=110658666745
Auction for it will start in 5 hours. Thanks -
eh? don't see anythingMain Surround -
