Carver TFM 24 or 25 junk/parts unit
nguyendot
nguyendot Posts: 3,594
edited March 2011 in Wanted (WTB) Classifieds
My TFM 25 has a bad input board (I think).
Looking for a TFM unit with the same RCA input board. If you have a junk unit or this piece alone, I would appreciate it.
The left channel is completely distorted, right channel is fine. Goes into protect if you turn it past 10%.
What's odd is if I swap the leads on the input board, the problem follows the channel of the board. I tested both sides of the amp and both channels work free and clear with the right channel of the input board.
I really don't want to spend $300+ to have it repaired when I know its something simple.
Main Surround -
Post edited by nguyendot on
  • Polkersince85
    Polkersince85 Posts: 2,883
    edited January 2011
    The TFM-25 was notorious for bad solder joints. especially around the transistors due to heat build up. Look the boards over closely.
  • nguyendot
    edited January 2011
    I had the entire input board desoldered and resoldered, with new transistors too! I don't know what gives :(
    Main Surround -
  • johnny4thqtr
    johnny4thqtr Posts: 1
    edited March 2011
  • nguyendot
    edited March 2011
    eh? don't see anything
    Main Surround -
