AudioArt ICs
Polkitup2
Polkitup2 Posts: 1,640
edited March 2011 in 2 Channel Audio
I run Wyred gear (DAC, Pre, and Amp) and was using MIT Shotgun S2 and S3 ICs and thought all was good. However, a few forum members mentioned that MIT ICs may not synergize well with the Wyred gear due to the impedence adjustments done by both the MIT cables and the Wyred gear. To test this theory I had Rob at AudioArt cables build me a couple pairs of hot rodded IC3s to replace the MITs. The AudioArt cables delivered substantially more crispness, sparkle, and resolution than I was getting with the MITs. The MITs sounded somewhat muddy in comparison. So synergy does matter and with Wyred gear AudioArt cables work very well. :smile:
Post edited by Polkitup2 on
  • joeparaski
    joeparaski Posts: 1,865
    edited March 2011
    Most of my interconnects are from Audio Art as well as my speaker cable. Don't ask me for any comparison though because I don't have a "golden ear". However, I can tell you that my system sounds very good to me.
    I suppose I could switch out to regular cables and see if there is a degradation in quality since I am used to the current sound. However, I don't really feel like doing that right now.
    Joe
    Amplifiers: 1-SAE Mark IV, 4-SAE 2400, 1-SAE 2500, 2-SAE 2600, 1-Buttkicker BKA 1000N w/2-tactile transducers. Sources: Sony BDP CX7000es, Sony CX300/CX400/CX450/CX455, SAE 8000 tuner, Akai 4000D R2R, Technics 1100A TT, Epson 8500UB with Carada 100". Speakers:Polk SDA SRS, 3.1TL, FXi5, FXi3, 2-SVS 20-29, Yamaha, SVS center sub. Power:2-Monster HTS3500, Furman M-8D & RR16 Plus. 2-SAE 4000 X-overs, SAE 5000a noise reduction, MSB Link DAC III, MSB Powerbase, Behringer 2496, Monarchy DIP 24/96.
  • ben62670
    ben62670 Posts: 15,969
    edited March 2011
    MIT's didn't do it for my system either.
    Ben
  • pearsall001
    pearsall001 Posts: 5,233
    edited March 2011
    Same here with MIT's...just didn't jell in my system. I do have an Audio Art PC for my Music Hall dac & it is performs extremely well. I've got to get around to trying their IC's & possible speaker cables down the road. I've heard nothing but high praise for the line.
  • jayman_1975
    jayman_1975 Posts: 672
    edited March 2011
    I use some audio art cables as well. IC 3 interconnects and the Power 1 power cables. Both are very good i find except i find the Power 1 makes my Cd player take on a brighter characteristic. The Power 1 is great on my amps though!
    Onkyo TX NR 5008 modified by The Upgrade Company
    Oppo BDP 93 modified by The Upgrade Company
    Arcam CD37
    Monitor Audio Gold GS 60
    Revolver Audio Music 5 towers.(surround)
    Vandersteen V2W
  • NotaSuv
    NotaSuv Posts: 3,871
    edited March 2011
    When I got my W4S int amp it was bought from the owner of Audio Art cables and at that time I went with their TOTL IC's and speaker cables (made me a deal I couldn't pass up ;) and the synergy with my system was fantastic.....had them do their in house burn in before shipping as well......Bob is a great guy to work with and knows his stuff...........great to see others are having the same positive experiences......have not tried any of their PC's yet....
  • SolidSqual
    SolidSqual Posts: 5,218
    edited March 2011
    Way to go Polkitup. Audio Art makes some nice ICs and Cables. After having MIT Shotguns in my W4S system, I came to the same conclusion with the addition of ICs and cables from MAC cables.
  • brgman
    brgman Posts: 2,859
    edited March 2011
    Has anyone compared the Audio Art IC's to the King Cobras?
    I have gotten speaker and power cables from Rob that i really like but no experience with the IC's yet.rob is one hell of a guy to deal with and makes nice stuff for sure.
    Thanks for the thread Polkitup2..
    I’M OFFENDED!!!!
  • bopicasso
    bopicasso Posts: 878
    edited March 2011
    Im thinking about trying these cables between my new ps audio dl III dac and my krell. Will xlr make a big difference over the rca offerings? Im interested in the se model ic. Thanks in advance:-)
    Living Room setup: Pioneer Elite VSX-21TXH, Krell KAV 300i, PS Audio DL III DAC, Tyler Acoustics Taylo 7u, Dynaudio Audience 120C+, SVS 25/31PCI, B-P-T Clean Power Center, Ps3, Panny 50" S1 Plasma, Tekline speaker cables, Audio Art interconnects, and Pangea power cables.
  • phipiper10
    phipiper10 Posts: 961
    edited March 2011
    I had King Cobras (and QA CV-6 speaker cables) prior to Audio Art ICs (IC3-SE) and speaker cables (SC-5). I think the difference like most things will be a matter of taste and equipment. I thought the King Cobra's were open airy and detailed but not harsh at the top. The bass wasn't remarkable in any way.
    The Audio Art drops some of the air and a bit of the leading edge IMO but gives back in more solid stage and cohesiveness across the spectrum. Things just seem a bit tighter and more locked in for me.
    Analog Source: Rega P3-24 Exact 2 w/GT delrin platter & Neo TT-PSU Digital Source: Lumin U2 w/Roon (NUC) DAC:T+A DAC 200 Phono Preamp: Rega Aria MK3 Preamp: Rogue RP-7 Amp: Infigo Method 6 Speakers: Joseph Audio Perspective 2, Audio Physic Tempo Plus Cables: Cardas Clear Reflection SC/IC, Shunyata PCs Misc: Shunyata Hydra Delta D6, VTI rack, GIK acoustic panels
  • zingo
    zingo Posts: 11,258
    edited March 2011
    Does't Audio Art use DH Labs raw cabling for their designs?
  • marvda1
    marvda1 Posts: 4,936
    edited March 2011
    the head guy at dh labs helped with the audio art design.
    Puritan PSM156
  • leftwinger57
    leftwinger57 Posts: 2,917
    edited March 2011
    I ,also am not of the GOLDEN EAR listening affciondos and the only difference I ever heard was taking apart my heavy duty RCAs and use Phillips Single ICs and truth be told I noticed some clarity or a cleansing if that is a true review.I have a very hard time coming to grips w/ people paying so much for their ICs. Justified ,I don't know, but I'd love to hear the difference......LW
