Any advantage using single/bi-wire speaker cable over traditional termination?
gfong
gfong Posts: 1,079
edited March 2011 in Speakers
In your opinion, what are the advantages of connecting speakers (RTiA9's) using a single to bi-wire configuration over the traditional termination?
If you could choose either, which would you use?
1. Traditional Amp end/Bi-wire speaker end
2. Traditional both ends
Post edited by gfong on
    F1nut Posts: 51,763
    edited March 2011
    If you use the single at the amp end to bi-wire at the speaker end the advantage is that you lose the cheap brass jumpers.
  • slammin86
    slammin86 Posts: 238
    edited March 2011
    I prefer the look of bi wire myself.
    Receiver: ONKYO 709
    Amplifier: Acurus A200x3
    Front: EmpTek E55Ti
    Center: EmpTek E56Ci
    Surround: EmpTek E5Bi
    Sub: Elemental Designs A5-350
    TV: LG 55"
    Blu-Ray: PS3
  • dnoyeB
    dnoyeB Posts: 114
    edited March 2011
    #1 is utterly useless.
    #2 can be used for bi-amping.
    Music
    LR: Polk Monitor 70 (willing to sell if interested)
    C: Cerwin Vega E-75C
    Sub: HSU VTF-2 MK3
    AVR: Sony STR-DE835
    AMP:
    HT
    5.1: Paradigm CT110
    AVR: Integra DTR-4.6
    WTB: RTiA9 or RTi12
    F1nut Posts: 51,763
    edited March 2011
    dnoyeB wrote: »
    No, it is not. See my comment above.
  • gfong
    gfong Posts: 1,079
    edited March 2011
    Thanks for the info, the debate goes on.
  • HTguru1982
    HTguru1982 Posts: 1,066
    edited March 2011
    I know others will disagree but I've never noticed a difference between traditional and bi-wiring. Leave the jumpers on, use traditional terminations on both ends and enjoy.
    Display: Sony 42" LCD
    Sources: Harman Kardon DVD-27,
    Panasonic DMP-BDT110 blu ray player
    AVR: Sony STR-DA2400ES
    Amps: Sonance Sonamp 260(fronts),
    Kenwood KM-894(surrounds)
    Fronts: NHT 2.5
    Center: NHT VS-1.2A
    Surrounds: NHT Super One
    Subwoofer: SVS PB10-ISD
  • dnoyeB
    dnoyeB Posts: 114
    edited March 2011
    I stand corrected. Let me remove "utterly" and restate.
    #1 is useless. :smile:
    Music
    Sub: HSU VTF-2 MK3
    AVR: Sony STR-DE835
    AMP:
    HT
    5.1: Paradigm CT110
    WTB: RTiA9 or RTi12
    F1nut Posts: 51,763
    edited March 2011
    Still playing with brass jumpers, eh?
    treitz3 Posts: 19,989
    edited March 2011
    There is no debate. Those that know, well, they know.
  • ben62670
    ben62670 Posts: 15,969
    edited March 2011
    I am using brass coat hangers for speaker wire:rolleyes:
    Bi-Wiring can be adventitious. The only time I find that to be true is if you use different types of cables for the highs and lows. I used Silver on the highs and AQ CV4's on the lows. You need to be careful if you go this go this route don't buy cables to do this. The cables need to play with each other. If the cables are different tone at the XO point then it will not sound right. Moral of the story??? Get a good set of single cables, change the brass jumpers out for some decent speaker wires, and use a single channel of an amp to drive the speakers.
    Enjoy
    Ben
