Best upgrade from RTi70's
BrettSelinsky
I have RTi70's up front R50's for rear. What do you guys think would be the best upgrade for the fronts? I would go new used or refurb for $300 to $500.
Thanks All
Thanks All
Brett Selinsky
Denon 3805
Denon DVD/CD
Crown ProAmp
JVC VHS
RTi70's Front
CSi5 Center
R50's Rear
DefTech Sub
Denon 3805
Denon DVD/CD
Crown ProAmp
JVC VHS
RTi70's Front
CSi5 Center
R50's Rear
DefTech Sub
BrettSelinsky wrote: »I have RTi70's up front R50's for rear. What do you guys think would be the best upgrade for the fronts? I would go new used or refurb for $300 to $500.
Thanks All
$300-500 for a pair? I'd suggest to stay with RTi70, since it will be very difficult to find a pair of better speakers in that price range (without making a lateral move, of course). For $500 a pair, you can upgrade to a pair of good bookshelf speakers, but you will need good sub and proper amplification for the ones, such as Polk LSi7 or LSi9.Panasonic PT-AE4000U projector for movies
Denon AVR-X3600H pre/pro
B&W CDM1-SE fronts
B&W CDM-CNT center
B&W CDM1 rears on MoPADs
DUAL NHT SubTwo subwoofers
Oppo BDP-93 Blu-Ray player
Belkin PF60 Power Center
Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room -
Some nice used SDA's would be in the price range.SDA-1C (full mods)
Carver TFM-55
NAD 1130 Pre-amp
The Clamp
Nakamichi CR7 Cassette Deck
Cambridge Audio DACmagic Plus
ADC Soundshaper 3 EQ
Ben's IC's
Nitty Gritty 1.5FI RCM -
Kelvin, I don't think SDA would run well on a Denon receiver, or any receiver to be exact... Just my opinion.Panasonic PT-AE4000U projector for movies
B&W CDM1-SE fronts
B&W CDM-CNT center
RTi10's or 12's. They'll match well with your CSi5 center. Or you can forgo the speaker upgrade and add a powered amp. There are some good choices in the $400-$500 range.Display: Sony 42" LCD
Sources: Harman Kardon DVD-27,
Panasonic DMP-BDT110 blu ray player
AVR: Sony STR-DA2400ES
Amps: Sonance Sonamp 260(fronts),
Kenwood KM-894(surrounds)
Fronts: NHT 2.5
Center: NHT VS-1.2A
Surrounds: NHT Super One
Subwoofer: SVS PB10-ISD
