Do RCA sub inputs bypass the crossover?
SpartanStang14
Hey,
So, since I got my PSW505, I've had an extra old, cheap powered sub laying around. I've been thinking about using it to add a sub when I hook my iPod up to things like small docks and other people's cheap computer speakers and such. I have a headphone splitter, so I would connect that to the iPod, and then connect the computer speakers into one of the headphone jacks, and then connect an RCA to headphone adapter into the other port. The RCA cables then go into the left and right RCA inputs on the sub. I know that the LFE input bypasses the sub crossover, but do the RCA inputs do the same? The only inputs on this sub are RCA and speaker level. If I do this, is the sub trying to play all of the frequencies? I'm hoping that the RCA inputs don't bypass the crossover so that I can play just the low freqs.
Thanks!
Thanks!
_______________________________________
AVR Sony STR-DH810
FRONTS Monitor 70 IIs
CENTER CS2 II
REARS Monitor 60 IIs
SUB PSW505
AVR Sony STR-DH810
CENTER CS2 II
SUB PSW505
Post edited by SpartanStang14 on
No, the RCA inputs go through the xover. Only the LFE input bypasses the xover.Turntable: Empire 208
Arm: Rega 300
Cart: Shelter 501 III
Phono Pre: dsachs consulting
Digital: Marantz SACD 30n
Pre: Conrad Johnson ET3 SE
Speakers: SDA 2.3TL, heavily modified -
awesome, thanks!_______________________________________
AVR Sony STR-DH810
CENTER CS2 II
SUB PSW505
