PSW505 sub packaging
vez
Hi,
I just bought a new PSW505 sub. There is packaging material (thin styrofoam kind) between the front grill and body of the speaker. Is this normal? How do I remove it safely? I am wondering if pulling out the grill to remove packaging will result in losing the snug fit of grill?
Any suggestions are appreciated.
Thanks,
Vez
Thanks,
Vez
Post edited by vez on
Hi,
Thanks,
Vez
No just pull off the grill, you're good to go.
