PSW505 sub packaging
vez
vez Posts: 2
Hi,
I just bought a new PSW505 sub. There is packaging material (thin styrofoam kind) between the front grill and body of the speaker. Is this normal? How do I remove it safely? I am wondering if pulling out the grill to remove packaging will result in losing the snug fit of grill?
Any suggestions are appreciated.
Thanks,
Vez
  • B Run
    B Run Posts: 1,888
    edited March 2011
    vez wrote: »
    Hi,
    Thanks,
    Vez
    No just pull off the grill, you're good to go.
