regarding that profile amp
Systems
Systems Posts: 14,873
edited February 2004 in Car Audio & Electronics
whats is the difference between CA640 & CL460 models, same rms pushed out.. is it just a cosmetic difference in the looks or is there other differences I should know about.
Testing
Testing
Testing
  • Jstas
    Jstas Posts: 14,985
    From what I can tell, the difference between the Clarus and California series amps amounts to this:
    California series has plated contacts and a 0-12 db bass boost network
    Clarus series has gold contacts and 0-18 db bass boost.
    All the other specs match. I think the Clarus line has a few more models in it. Otherwise, I can't justify paying more for the same amp.
    Expert Moron Extraordinaire
  • Systems
    thanks, your help is appreciated....
    in your opinion is that minor difference worth the extra 10/20 dollars or is it so minor that it wouldnt be worth it.
    Testing
    Testing
    Testing
  • Jstas
    Jstas Posts: 14,985
    Thought I went over that already.
