Rears/sub for monitor 60's
SuperSpray
So I started with my HT.
So far I have a Polk Audio CS1 Series II center, and two Monitor 60 series II as the fronts. I just want a 5.1 setup.
Right now I'm looking to buy either rears or a sub (possibly both) as money permits.
Can someone recommend some rears and a sub that would go with this setup?
My first system was monitor 60's, Cs1 center, monitor 30's in the rear and a psw505 sub. I liked it a lot, you get a lot of bang for your buck. If you have room check out the monitor 40's, if not the 30's worked fine for me. The 505 blends nicely and sounds good with the rest of your system. Welcome to club polk!
