Adcom 7605 switch
K-daugh
hey guys so i just picked up some of the premium 3.5mm plugs from monoprice sent one from my ir repeater to my remote in jack on my hk avr247...Then i went from the remote out jack on the hk to the 12vdc jack on the back of the adcom...the hk turned on fine but the adcom just keeps switching itself on and off with every button i push...
When i go to power up the system the amp freaks out and turns it self on and off like ten times ...then off goes the adcom until i press a button then it freaks out again...so what am i doing wrong? is it the cable? is it the hk?or is it the adcom?maybe a fuse...i dunno need some help please
Budget 5.1 H.T. Set Up
HK avr 247 - Adcom GFA-7605Mirage Bps 150i powered sub - 40"Samsung LCD ln40c530 - Sony Blu Ray Player BDP-S370 - Comcast digital hd box(motorola dcx3400)
Monoprice Premium Interconnects Monoprice Ultra Slim HDMI w/Redmere
Custom Jumpers
Post edited by K-daugh on
bump....please help meBudget 5.1 H.T. Set UpHK avr 247 - Adcom GFA-7605
- Belkin PF60 Power Conditioner - Cs2 center channel - Monitor 60's fronts - Monitor 30's rears
-Knukonceptz Kord 10 Gauge Speaker Wire - Nakamichi Banana Plugs
Custom Jumpers -
That is a remote jack. It's not for plugging in amps.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
Seems like it. Is there a specific amp out jack? DC trigger? or a 12VDC trigger?2Ch Tube Audio Convert
damn that sucks!!! i was hoping.... my rig is in the closet so it kind of blows that that wont work....would it hurt anything to just leave the amp on all the time???Budget 5.1 H.T. Set UpHK avr 247 - Adcom GFA-7605
Custom Jumpers -
or is there any other way of doing it ....could this be a reason to upgrade my receiver ..lol does the hk 354 have an amp out jackBudget 5.1 H.T. Set UpHK avr 247 - Adcom GFA-7605
Custom Jumpers -
They call it a 12v trigger. I just leave my amp on. If you don't use it much it's not that hard to push the power button.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
I thought the 12 volt trigger was built into the amp....will leaving it on hurt it in any way?Budget 5.1 H.T. Set UpHK avr 247 - Adcom GFA-7605
Custom Jumpers -
I used to leave my amps on 24/7. Some say that turning equiptment on and off stresses gear more than just leaving it on. Also some gear sounds better when warmed up.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben
