Now what?
standj77
Okay, i posted about my subs not hitting as hard as i wanted. That seems to worked itself out, guess they needed broke in i guess. Anyway, now after a little while, the bass gets softer. They hit hard for a while, then its like the amp goes dead or something. any answers?
Post edited by standj77 on
Youre getting used to the volume level after a few minutes. Ever notice how when you get back into your car and crank it up, the radio is loud as hell? While youre driving, your ears get used to the louder volume cause its having to contend with road and wind noise. Same thing here.
Only other thing I can think of would be your battery is old and losing its capacity so it weakens as you drive.
That might be the problem, but Im kinda leaning to its your imagination. Youre fixated on loud subs - so youre gonna be susceptible to your mind playing tricks on you.polkaudio sound quality competitor since 2005
Or your amp is losing efficiency as it's getting hotter..Main Surround -
Den - Rotel RSP-1068 / Threshold CAS-2 / Boston VR-M60 / BDP-05FD -
Loosen up a few bolts and clips in your car, that will greatly imrove your mind playing tricks on you in a good way as per what you expect from subs
2008 Nissan Altima
Kenwood DNX 5140
Arc Audio IDX and XEQ
Polk Audio SR6500 active and SR124-dvc sealed
Polk Audio PA500.4 and PA1200.1
