smoke coming from subs
aryiah
aryiah Posts: 5
I have a MTX audio 1000XD 2000W max, X Thunder series 1-channel class D mono car amp. It can produce 4 ohms: 500w RMS x 1 chan or 2 ohms: 1000w RMS x 1 chan. I have it hooked up to 2 polk audio mm1240 12" svc 4 ohm subs 800 watts max each and 425 watts RMS each. I have speaker wire running from the + and - of the amp going to the + and - of one sub and speaker wire going from the + and - of that sub going to the + and - of the second sub. I think i have it hooked up so that the amp produce 4 ohm: 500 watts RMS to each sub. When i turn them up loud smoke come out the two port holes of my sub box and the smoke has a burnt wire smell. Iv'e had my subs about a month and they still sound good. Do anyone know why they smoke when i turn them up loud?
Post edited by aryiah on
  • BlueFox
    BlueFox Posts: 15,250
    edited February 2011
    Maybe they need an air-hole. Or maybe not.
  • ben62670
    ben62670 Posts: 15,969
    That's 2ohms and 1000watts. You most likely over powered them. I have heated voice coils before and almost smoked them, but I caught it on time to prevent failure. Sounds like you need to adjust the levels of your amp.
    Ben
    Ben
  • quadzilla
    quadzilla Posts: 1,543
    You can't hook 2 4 Ohm subs up in any configuration that will result in 4 Ohms. You can have 2 Ohms or 8 Ohms. From what you describe, you're most likely running a 2 Ohm configuration. Still, since each speaker is rated 800 watts, that 1000 watt amp shouldn't be too much power. Since the smoke is coming out of the port holes, I'm going to go with that box has cheap small gauge wire you're burning the insulation off.
    But really, the best best is to pull the drivers out of the box and take a look and see what's going on. Or we can sit and guess.
    Turntable: Empire 208
    Arm: Rega 300
    Cart: Shelter 501 III
    Phono Pre: dsachs consulting
    Digital: Marantz SACD 30n
    Pre: Conrad Johnson ET3 SE
  • aryiah
    aryiah Posts: 5
    ben62670 wrote: »
    Ben
    Thanks, that sounds like what i need to do, then later i'll get 2 more subs just like the ones i have and have the amp push all 4 of them. ? would that mean that each sub would be getting 500 watts RMS since the amp would be sending 4 ohms to each sub. Thanks for your help Ben.
  • aryiah
    aryiah Posts: 5
    quadzilla wrote: »
    Thanks for your answer, how can i hook the subs up to run 8 ohms, and would they still sound good, thanks once again.
  • JimAckley
    JimAckley Posts: 1,138
    BlueFox wrote: »
    Epic :biggrin:
    - Computer Rig -
    YAΘIN MS-20L, polkaudio RT5
    - Main Rig -
    Pioneer SC-37, Overnight Sensations, Samsung 52" LCD
    - Currently In Progress -
    Curt Campbell's Uluwatu LCR, LMS Ultra Gjallarhorn, JBL W15GTi stereo subs, 2.1 entertainment system for the gf
  • quadzilla
    aryiah wrote: »
    Run the + from the amp to + on one sub, then run - to the + on the other sub, then run the - from the second sub to the - on the amp. That's 8 ohms, since the subs are in series.
    They shouldn't sound any different. But I'd really seriously advise you to pull the subs and look at the wiring in the box and see if it look melted and/or burnt.
    Arm: Rega 300
  • aryiah
    aryiah Posts: 5
    quadzilla wrote: »
    I'll do that soon as my wife gets back with our car and i'll let you know whats up with that. thanks for your help
  • aryiah
    aryiah Posts: 5
    aryiah wrote: »
    OK friend just checked the speaker wire inside the sub box and it still looks brand new, the speaker wire is thick it's not that cheap thin wire. smelled the sub itself and smelled a fant burnt wire smell from them. maybe the voice coil wire start to burn some that day i had them up real loud. Anyway just turned the gain on my amp down from half way up to just a quarter of the way up now but i turned my bass boost, sub filter and frequency response to 3/4 of the way up. Do you think this will be ok?
  • quadzilla
    Why are you turning the subs down but turning bass boost up? That seems to defeat the point. So, probably going back to what someone else said: you're probably overdriving the subs.
    Arm: Rega 300
