Mounting Polk Audio 5Jr Speakers
rsgoldflam
rsgoldflam Posts: 3
Can anyone tell me the best way to mount these speakers to the wall? Can I drill into the cabinet? I am hooking up the speakers to my tv and want to finally mount the speakers. Any help would be much appreciated.
Post edited by rsgoldflam on
  • quadzilla
    quadzilla Posts: 1,543
    edited February 2011
    Drilling into the cabinet would not be recommended. The recommended way would be to get stands that put the tweeters at the same height as your ears when you're sitting. Also, wall mounting speakers just sucks in general.
    Turntable: Empire 208
    Arm: Rega 300
    Cart: Shelter 501 III
    Phono Pre: dsachs consulting
    Digital: Marantz SACD 30n
    Pre: Conrad Johnson ET3 SE
  • rsgoldflam
    rsgoldflam Posts: 3
    Thanks Quad. I know it isn't ideal to mount the speakers to the ceiling/wall, but I need o get them off my stands.
  • rsgoldflam
    rsgoldflam Posts: 3
  • quadzilla
    The answer is, there isn't really a good way to wall mount those, because they aren't designed to be wall mounted. If you really really have to though, then I would go with a shelf mounted to the wall, and set the speaker on the shelf. Probably want to use a triangle brace when you do it, so the shelf doesn't collapse.
    Arm: Rega 300
