M30 bookshelf and CS10 center speaker?
Theendgamelv3
Theendgamelv3 Posts: 7
edited February 2011 in Speakers
I am a newbie when it comes to audio and I was wondering if it is ok to mix product series. I was looking at the M30 speakers and I saw a CS 10 center for a good price. Would these speakers work together pretty well or should I get a CS1/CS2 which are apart of the same product series as the M30 speakers?
Post edited by Theendgamelv3 on
  • ROHfan
    ROHfan Posts: 1,014
    It should work fine. The CS1 and CS10 are almost identical except for the cabinet style. They both use the same drivers and tweeters. I use a CS10 between two Monitor 60's and I love it.
    TV: 65" Samsung QLED 4K
    AIYIMA Tube T7 preamp --- Nobsound 12AX7 tube preamplifier
  • rooftop59
    rooftop59 Posts: 8,120
    negatory ghostwriter. They use different midwoofers and tweeters and probably different crossovers. Now granted the sound is similar. But I would recommend saving for a cs2 as it will be great for movies and match the m30s well.
    Game Room 5.1.4:
    Bedroom 2.1
  • krauley
    krauley Posts: 81
    ^ I agree with rooftop59 ^
    as far as getting the cs2 instead and its on sale atm at newegg:
    http://www.newegg.com/Product/Product.aspx?Item=N82E16882290212
    Onkyo 808
    Emotiva XPA-5
    Polk Audio M70s fronts
    Polk Audio Cs1 center
    Polk Audio 50s surrounds
    Polk Audio 30s backs
    Polk Audio Psw505 sub
    Polk Audio Psw10 sub
    Oppo BDP-93
    PS3 slim 250gb
    Vizio 55" Led-lcd
    HTPC Evga P55/Intel i7-860/Evga 260 Sli
  • ROHfan
    ROHfan Posts: 1,014
    krauley wrote: »
    Sorry bout that. The specs are the same and the pics of the drivers are the same so I thought it was the same drivers.
    Wow, that's a kick **** price for the cs2! Love the Egg.
  • starless
    starless Posts: 23
    ROHfan wrote: »
    I got mine for $20 cheaper than that from newegg a week ago!:biggrin:
  • Geoff4rfc
    Geoff4rfc Posts: 2,927
    I have a CS2 and M30's in the surround position. After listening to the CS1 and 2 back to back, there's no way I'd settle for the 1. The 2 can put out the sound without strain. The 30's put out a surprisingly amount of awesome sound just in my surround spot.
    Set up: 11.2 HT + 2ch
  • Florida_Gator
    Florida_Gator Posts: 54
    I just installed my new CS20 tonight (replaced a CSR) and it sounds GREAT with my R50 mains.
    The CS10 would match the M30s fine, IMO.
    That said, if you think you might upgrade your mains later and cascade the M30s, then get a CS20.
    Florida_Gator
    TV: Sony 60NX810 60" 3D LED
    Front R/L: Polkaudio MonitorII60s
    Center: Polkaudio CS20
    Surround R/L: Polkaudio MonitorII30s
    Rear R/L: Polkaudio R150
    Sub: BIC F12
    A/V Reciever: Onkyo TX-SR505
    Stuff: HD-DVR, Sony BRP 570, PS4, WiiU, XBoxONE
  • Gulfstrings
    Gulfstrings Posts: 313
    We have the CS1 in our bedroom system. It's matched beautifully to its speaker mates; Monitor 40 Series II fronts and Monitor 30 Series II surrounds and PSW 111 sub.
    It does a great job presenting TV and movie dialogue as well as musically when in multi channel mode. I also own a CS2 and I'm sure it would have worked as well, but the CS1 was smaller and fit well with everything both dimensionally and as part of the sound package.
    I believe I purchased it on sale a Newegg for $69. You wouldn't be disappointed with either.
    I preferred the CS1 between my choices.
    Here's what Polk recommended with the original series:
    Front Center Surround Subwoofer MSRP USA* MSRP Canada*
    Monitor 40 CS1 Monitor 30 PSW110 $1089.80 $0.00
    Monitor 40 CS2 Monitor 40 PSW125 $1449.80 $0.00
    Marantz AV7005
    Marantz MM7055
    Onkyo DX-755 CdP
    Oppo BDP-93
    Technics SL-1301/Shure M97xE
    Polk RTi A7s
    Polk CSi A6
    Polk FXi A6s
    Velodyne VDR10-BV
    Panamax M5100-PM
    Antec VERIS A/V Cooler x 2
  • Geoff4rfc
    It almost sounds as if you never hooked up your CS2 due to size and installed the CS1.
    Is that true? I don't know of anyone that owns both CS1 and 2 and actually prefers the smaller speaker from an audible perspective.
  • Gulfstrings
    Geoff4rfc wrote: »
    The CS2 was part of that system in the beginning. The CS1 was brought in to better fit the bedroom setup. They were not A/Bd in that setup, persay, but I do prefer the CS1. To us it carries both dialogue and music better than the CS2 did in that room.
    That CS2 was at one time part of my primary system (see sig) for a while before the CSi6 arrived.
    It now lives in my electronic boneyard with other commponents that should have been something they weren't.
    Visit my system showcase to view how it's setup. Perhaps placement, room dimenstions, etc will better explain how it can be true.
    http://www.polkaudio.com/forums/showcase/view.php?userid=106014
    Marantz AV7005
    Marantz MM7055
    Onkyo DX-755 CdP
    Oppo BDP-93
    Polk RTi A7s
    Polk CSi A6
    Polk FXi A6s
    Velodyne VDR10-BV
    Panamax M5100-PM
  • Geoff4rfc
    Right on bro, thanks for the explanation. How do you like the i6 compared to the CS2? And........what all do you have in your "boneyard"?
