MONITOR 40 VS RtiA3. Is it worth the difference
Hi, I'm looking to buy some bookshelves and saw the monitor 40 (two drivers) can be had for half the price of the RTIA3 (One driver). Is the Rti that much better speaker to justify the double in price? Any opinions/experiences would help. Thanks
Post edited by fyrn on
Yes it is, it has better quality cabinets, crossovers, drivers, tweeter and a better sound. It's much more detailed in the upper end.
+1 to that!
Also, you could visit the Polk Ebay direct outlet and pick up a pair of RTiA3s for only $249 for the pair - could now be cheaper than the price you saw for a pair of new Monitor 40s!
Another vote for YES. I have not owned the a3, but did own the rti6 (previous similar model) and the m40 before that. The rtis give you a bigger stage, more detail on the top end, tighter bass, etc. Having said that Do they sound 2X better? are they worth 2X the price? That is very subjective. I think they sound significantly better, but whether not its worth it only you can decide.
I would recommend looking for the rti6s used if you like the look of them, as they are very similar and much cheaper on the used market.Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
The rtia3, sounds better at higher levels,,, No smearing,, just a better all around speaker,, JMO,Not an Audiophile, just a dude who loves music, and decent gear to hear it with.
Thanks for the input so far, I'm new at this and I forgot to mention that they are going to be use mainly for music. I don't know if that matters.
I have also seen the RTI4 which I believe is just a smaller version and much cheaper. Is the comparison the same? -
I originally upgraded from the m40s to the rti4. Major difference, especially for music. I now think that the rtis are a little on the bright side. My favorite polk tweeter in that line is from the rt25i and 35i etc. here is a link to a really good looking pair that is basically the rti a3 from several generations ago. I would personally go for this or a pair of rt25is.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=220742921490&ssPageName=STRK:MEWAX:IT
There are lots of guys here like me who prefer that generation of rt/rti, but of course also lots of folks who like the newer ones. If you have never heard either then you will probably like any of the above and all are major upgrades over the monitorsLiving Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
Rti4 is the old version of RTi a1's.
I own the a3's, and they are spectacular in SQ. They put out sound as if you were listening to towers (some towers--not like the a7 or a9's!)Polk Audio RTi A3 (mains)
Polk Audio CSi A4 (center)
Polk Audio RC60i (rears)
BIC Acoustech PL-200 (sub)
Denon AVR-590 (receiver)
Samsung LN46B550 (LCD)
Sharp BD HP22U (Blu-ray player) -
Sounds like time to upgrade from my M40s.
yeah very good upgrade.Home Theater:
Processor: Emotiva UMC-1
Amps: Emotiva XPA-3, Emotiva UPA-5
Center: Polk Audio CSi A6
Fronts: Polk Audio RTi A7
Surrounds: Polk Audio FXI A4
Surround Rears: Polk Audio RTI A3
Subwoofer: SVS 2039 PCi (upgraded woofer)
Power Conditioner: Monster HTS 5100 Signature Series
2 Channel: (work in progress)
Speakers: Polk Audio Monitor 40 -
I have read where a lot of people are of the opinion that the RTI is to bright for music and might not be a better choice over the monitor for this application. What is the consensus?
Nonsense. :rolleyes:
I totally enjoyed my RTiA3s for music.
Unless you like thrash metal at ear piercing volumes they do a very good job with music especially when mated to appropriate electronics.
I agree that is nonsense. Music sounds wonderful. The old RTi line was bright, the but the RTi A line has greatly improved on that aspect.Polk Audio RTi A3 (mains)
Have a pair of Monitor 40's I used to use as Surround speakers, while I loved the sound, I too agree that the RTiA3's would be a good upgrade.
-JeffHT Rig
Receiver- Onkyo TX-SR806
Mains- Polk Audio Monitor 70
Center- Polk Audio CS2
Sub- Polk Audio PSW125
Blu-Ray- 80 GB PS3
2 CH rig (in progress)
Well i guess i need to get my ears on some rti a1s or 3s...would be interested to listen for the aformentioned improvements...Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
Thanks for the input. Nobody where I live carries the RTI A3 line so I can demo them but there is a best buy that has some TSI 400 that I can listen to. Would those (400) be comparable in sound to the A3's or are the RTI's still much better?
I'm not sure about better/worse, but the 400's will be different from the rti a line. They are known for greater clarity/detail over the tsi's, which you can't test by comparing upper tsi's with lower RTi's. At least that's my opinion.Polk Audio RTi A3 (mains)
ShadowTowel wrote: »I'm not sure about better/worse, but the 400's will be different from the rti a line. They are known for greater clarity/detail over the tsi's, which you can't test by comparing upper tsi's with lower RTi's. At least that's my opinion.
Look at the difference in construction, material. design in the PRODUCTS.
I looked hard, decided on RTiA. I spent more than my wife expected.
From what I could hear, the tsi is hard to beat at that price point.
I really prefer the sound of tsi400 Polk over the Klipsch= more $ at Best Buy. -
So fryn, and decision made?Polk Audio RTi A3 (mains)
With the RTi As your not just paying for sound. Your paying for wooden construction.Music
LR: Polk Monitor 70 (willing to sell if interested)
C: Cerwin Vega E-75C
Sub: HSU VTF-2 MK3
AVR: Sony STR-DE835
AMP:
HT
5.1: Paradigm CT110
AVR: Integra DTR-4.6
WTB: RTiA9 or RTi12 -
...With the RTi As your not just paying for sound. Your paying for wooden construction.
Are you being facetious or is that really your impression.
Combo rig:
SDA 1C, CS400i, SDA 2B
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
RTi A are made of wood, Monitor's are made of fiberboard. I don't think Polk is eating the cost!?Ron Temple wrote: »...
Are you being facetious or is that really your impression.Music
Sub: HSU VTF-2 MK3
AVR: Sony STR-DE835
AMP:
HT
5.1: Paradigm CT110
Both are MDF, yes the wood veneer, design, power port and construction cost more, as do the drivers and crossover. However, your statment implies that there is no difference between the speakers except wood. That's not true. The RTiA is a superior product.RTi A are made of wood, Monitor's are made of fiberboard. I don't think Polk is eating the cost!?
Combo rig:
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
I think you need to reread dnoyeB's statement:Ron Temple wrote: »However, your statment implies that there is no difference between the speakers except wood. That's not true. The RTiA is a superior product.
"With the RTi As your not just paying for sound. Your paying for wooden construction."
The key words being "not just." It is clear that he is saying that the sound is not the only reason for the price difference. He is saying that the higher quality construction also plays a role. -
I did misread it...sorry dnoyeBI think you need to reread dnoyeB's statement:
Combo rig:
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
As I have stated in other threads, I love my RTiA1s for two channel. Had the chance to audition A3s and several other higher end bookshelf speakers, including Thiel and B&W, and thought they performed very well in comparison...Don't forget to enjoy the music...
How, in your OP, is the rtiA1, a better speaker than the rtiA3??? The 3 has a bigger soundstage,, and deeper bass, just curiouse,As I have stated in other threads, I love my RTiA1s for two channel. Had the chance to audition A3s and several other higher end bookshelf speakers, including Thiel and B&W, and thought they performed very well in comparison...Not an Audiophile, just a dude who loves music, and decent gear to hear it with. -
Wow, interesting. I auditioned both for fun after I received my A3's and cannot understand how anyone could prefer the A1. The A1 is awesome, but I find the A3 quite superior.Polk Audio RTi A3 (mains)
I wish I had a local place to demo all of this stuff.Receiver: ONKYO 709
Amplifier: Acurus A200x3
Front: EmpTek E55Ti
Center: EmpTek E56Ci
Surround: EmpTek E5Bi
Sub: Elemental Designs A5-350
TV: LG 55"
Blu-Ray: PS3 -
I think what there saying is being the RtiA1, has a smaller driver, so it will normally have better imageing, more detail, and have a tighter quicker sound,, I found this to be true when i A and B,ed my rt5,s against my rt25i,s the 25,s smoked the rt5,s in detail,, and were more accurate, but the rt5, had more bass, so as stated, i guesse its what your looking to accomplish,ShadowTowel wrote: »Wow, interesting. I auditioned both for fun after I received my A3's and cannot understand how anyone could prefer the A1. The A1 is awesome, but I find the A3 quite superior.Not an Audiophile, just a dude who loves music, and decent gear to hear it with. -
Yeah I'm lucky to have a Fry's nearby. Nice for demos! You don't need demos for this one though (to me) - there is a good reason the A3's cost more!
Surfer - you're saying the only thing better about the a3 over the a1 is bass response? In other words, me who has a sub would get better quality from the a1's, and better imaging? I find that hard to believe. By that theory, you may as well get some tiny speakers with tiny drivers if less is more.
Also, by that theory, my csi a4 is better than the csi a6 (which is the clear favorite everywhere I have looked, including this forum). I think the 6.5" driver is superior to the 5.25" for more than just bass. Correct me if I'm wrong though. You guys definitely know way more than I do. I just keep hearing how the a6 is superior to the a4 (by a wide margin I might add), and the only difference I see is driver size (and in turn, weight, depth, and width).Polk Audio RTi A3 (mains)
