Dynamic Range Database
Erik Tracy
Erik Tracy Posts: 4,673
edited February 2011 in Music & Movies
Saw this posted today over at AK:
http://www.dr.loudness-war.info/
Hopefully this isn't 'old news'.
Kinda cool..take it for what its worth...
Post edited by Erik Tracy on
    F1nut Posts: 51,763
    I posted a link in another thread before I saw that you had posted this, sorry.
    Good info, that needs to be seen.
  • muncybob
    muncybob Posts: 3,239
    cool, wish it were more up to date though.
    Yep, my name really is Bob.
  • steveinaz
    steveinaz Posts: 19,545
    I thought about polling people here, and creating a database for CD quality, based on a 1 to 5 star rating, but it's more work than I'm willing to do...
    Take an average rating from peoples submittals on how they thought a particular CD sounded, this of course would (or should) take "loudness wars" into the rating. It would work like this:
    * Poor (unlistenable, a beer coaster)
    ** Fair (listenable, but lacking body, soundspace, suffers from some digital glare)
    *** Average (a respectable recording, with some minor flaws)
    **** Excellent (above average, but not quite reference material)
    ***** Reference recording (The best of the best)
    F1nut Posts: 51,763
    muncybob wrote: »
    It is up to date. The dates you see listed are when the recording was released, not when the info was posted.
  • vc69
    vc69 Posts: 2,500
    Good stuff. Thanks Steve.
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    Muscial Fidelity M1 DAC
    VTL 2.5
    McIntosh 2205 (refurbed)
    B&W 801's
    Transparent IC's
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    Can someone explain what I'm looking at?
  • Erik Tracy
    green is good
    red sucks.
  • steveinaz
    Once you get familiar with your volume control position, you can tell the overly hot recordings (poor dynamic range)--if they are not easy to tell audibly. Anything that sounds moderately loud at 9 o'clock on my pre I know its recorded too hot, and then I listen for other tell-tale signs of the loudness wars. I find interesting that most everything I have from the 70's to early/mid 80's requires far more volume, then later recordings.
    One recording that has excellent dynamic range is George Michael's "Faith" CD. That CD will sneak up on you and peak your amp in a quick hurry. It's not "loud" it's just got big dynamics. Notably "Hard Day."
  • AsSiMiLaTeD
    Erik Tracy wrote: »
    green is good
    red sucks.
    Thanks, I gathered that (also I can read), I was looking for a more in depth explanation.
  • AsSiMiLaTeD
    I'm shocked to see some recordings, like In Absentia, that are generally considered to be good recordings but get poor results on that scale.
  • Erik Tracy
    Sorry - was a bit glib with that. :redface:
    What part doesn't make sense?
    I see it as a spread rating from 1-20 for the dynamic range for each title in question with an average rating for the album overall and then a worst and best column for the tracks on that album.
  • AsSiMiLaTeD
    I should probably do some reading up on dynamic range then. I suppose prior knowledge is implied or expected, but if I were putting something like that together, I'd have a short blurb on what it is and why it matters and then show the results, but maybe I missed that part.
    Is there an objective means of measurement, or are people just rating based on what their ears tell them?
  • Erik Tracy
    Probably just what their ears tell them - kinda like the way they rate bluray discs over at AVS for their 'tiered' rating for picture quality which is...gasp....all subjective....!!! :tongue:
  • muncybob
    Yep, I get that. But I looked for a few releases in the last couple years and did not find them.
  • steveinaz
    There is a multitude of scope measurements on youtube if you search the terms "loudness wars" that shows the clipping of the peaks, destroying dynamic range. I don't know what software they are using, but that seems to be one way to find out....
    Some videos also play remasters that have been ruined my the loudness wars, and compare them to the early releases which are far better. You can easily hear the difference between the samples.
    Remaster doesn't always mean "better." My early release Boston CD is far better than the "squashed" remaster of the same CD.
  • mrbigbluelight
    mrbigbluelight Posts: 9,878
    Good case in point might be SuperTramp's "Crime of the Century" releases.
    http://www.dr.loudness-war.info/index.php?search_artist=Supertramp
    The 1974 Remastered Release has an Album DR of .... 9
    The 1974 Releases in MFSL (and Gold) are 16 (and 17).
    Kind of a bad example, I guess, comparing MFSL to regular remastered, but the "remastered" edition is as flat as unleaven bread.
  • steveinaz
    I have the original Crime of the Century release (not a remaster), it sounds very good. I would rate the CD between average and excellent overall, leaning more towards excellent. It lacks a little punch, but overall tonal character is very good. treble is excellent.
  • Erik Tracy
    steveinaz wrote: »
    I have the same CD - I would agree with Steve's assessment - pretty darn good for a standard issue CD.
  • steveinaz
    I love rocking "Bloody Well Right" at concert levels. The soundstage is HUGE. That track would be off the hook on SDA's.
  • unc2701
    unc2701 Posts: 3,587
    It's kind of sad sorting that list from best to worse and seeing how few there are from the 2000's that are any good.
    Backburner:Krell KAV-300i
  • steveinaz
    The real shame is that some of the "remasters" are worse than the orignal releases. I mean, why even bother? My Boston remaster sucks, I use it as a coaster now and listen to my original release.
    pitdogg2 Posts: 27,045
    ok looking through i seen what i thought were some SACD's the listing says SHM-CD that seemed to be in the red. So if i'm correct why would a SACD be so compressed wouldn't that go against what SACD is all about?
    help me here
    F1nut Posts: 51,763
    An SHM-CD is not an SHM-SACD.
  • unc2701
    ...and SACD's aren't immune from idiot mastering.
    However, you should probably check out the loudness wars videos on youtube- they explain the problem very clearly; we're not talking about digital compression, but dynamic range compression (although lossy digital compression algorithms tend to utilize some dynamic range compression).
