Missing Power cord to Ac/Dc Adapter
lhenion
lhenion Posts: 1
I just purchased as used Polk Audio Soundbar (model SDA) and it is missing the power cord to the Switching adaptor (part RE-1807-1). The output is 24 V and 2.7 Amps. Can I just go down to my loal radio shack and purchase any cord that will fit the connection or do I need to match the specs on the adapter? Also is there a place on line that I can just purchase the cord?
Loyd
Post edited by lhenion on
  • kawizx9r
    kawizx9r Posts: 5,150
    edited December 2010
    Well, the manual doesn't state whether the power adapter is two pieces (brick+cord or all one piece).
    If it's the 'brick' (laptops use it too) that you're missing, then match the specs. Make sure you get one with the right polarity -
    If it's just the cord that connects from the brick to the wall, any will do. Just make sure you get the one with the proper female end on it.
    Btw, welcome to CP!
    -Freddy
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • etrillan
    etrillan Posts: 1
    edited February 2011
    lhenion wrote: »
    Loyd
    Were you able to find a power adapter for this? I'm on the same boat... not sure if I should just order a universal adapter, or order from polk.. I emailed polk, but they still haven't gotten back to me.
    Let me know what you ended up doing, Loyd.
    Thanks!
