Newb wants pairing confirmation
Skormy
Skormy Posts: 11
After a home remodeling project, want to make sure I'm on the right track on in audio department.
I've got an Onkyo tx sr505 for my receiver, which I've had for a couple of years. On the speaker department, here's what I'm looking at picking up:
Main speakers: Audio Monitor 70
Sub: (likely) a PSW505 or PSW111 -- preferences
Center: CS10 (20?)
I'm going to wait on the rear, as the room configuration dictates I need to go wireless, and the new audio along with the new plasma will be a big first step. Though I am willing to take wireless surround advice if folks offer it up.
My primary question is -- are the speaker pairings I'm leaning towards simpatico? thanks in advance.
Post edited by Skormy on
    tonyb Posts: 33,072
    edited January 2011
    Hit up the 505 sub, and the cs20 to gell with the M70's and you should be a happy camper.
  • Skormy
    Skormy Posts: 11
    edited January 2011
    Why the CS20 over the CS10?
  • dorourke07
    dorourke07 Posts: 298
    edited January 2011
    The center is the most important piece for HT. The larger unit will better mix with the towers.
    Mains - LSi9's
    Center - LSiC
    Surround - pair of TL3's
    Amplification - Parasound 2125
    AVR - Onkyo 706
    CD/SACD - Onkyo DV-SP506
    SUB - MartinLogan Abyss
    55" Panasonic Viera TC-P55GT30 3D
    Bluray - DMP-BDT310 Panasonic
  • inthewoods
    inthewoods Posts: 54
    edited January 2011
    Skormy wrote: »
    Because Polk says so (actually it's CS2) :biggrin: http://www.polkaudio.com/homeaudio/products/recent/monitor70/
    Panasonic 58" Viera S2 Plasma | Onkyo TX-SR608 | Monitor 70 Series II | CS2 | PSW505 | RC60i
  • djperez81
    djperez81 Posts: 388
    edited February 2011
    the cs2 is a better timbre match for the 70's and i would go with the 505 over the 111. Good luck and enjoy
    Music doesn't lie. If there is something to be changed in this world, then it can only happen through music.
    -Jimi Hendrix
  • Skormy
    Skormy Posts: 11
    Is there a big difference between the CS2 and the CS20? As a bit of a newb, it can be a bit confusing.
  • On3s&Z3r0s
    On3s&Z3r0s Posts: 1,013
    Based on the specs it doesn't look like there's a big difference, and I get confused between them all the time (even though I should know since I have the Monitor 70's and the CS2). But, the CS2 uses identical drivers to those used in the Monitor 70's so they should match better. The CS20 matches the TSi series of speakers.
  • Skormy
    Skormy Posts: 11
    Thanks for all the feedback. My plan may have just hit a possible snag. My entertainment unit's opening where I had envisioned putting the CS2 is only 8" high. The CS2, according to the specs, is 7 3/4" high. Is this too tight an enclosure? Though this matches better with the 70s, am I better off with the CS20 which measures 7 3/8" high. I don't want too tight a fit? The good deal I found for the CS2 and the Monitor70s expires tomorrow. Appreciate any feedback.
  • mdaudioguy
    mdaudioguy Posts: 5,165
    I'd say you're fine. Go for it! :smile: Really, you shouldn't have any problems.
  • Skormy
    Skormy Posts: 11
    So 1/4" is sufficient clearance. Just want to double confirm before I pull the trigger. Would have private messaged you, but I don't have enough posts. Thanks so much.
  • Skormy
    Skormy Posts: 11
    Placed the order for the CS2 tonite. Hoping that it's a relaxed 1/4" and that if fits like a comfortable glove. Next question. What type of speaker wire would folks recommend for the Monitor 70 and CS2. And with these speakers, are any pin connectors or plugs recommended/suggested. What gauge and brands are worth looking at. Thanks.
  • mdaudioguy
    Skormy wrote: »
    I don't see where additional clearance would be of any significant benefit. If anything, it sounds like everything will fit together nicely (from an aesthetic perspective). If you have any concerns upon receiving the speaker, be sure to include a picture. I'm assuming that side clearance isn't an issue.
  • mdaudioguy
    Skormy wrote: »
    Some 14 gauge speaker wire, like from monoprice (.com), would be a great starting point. Banana plugs would make connecting and disconnecting easier, if you're going to be doing it repeatedly. Otherwise, bare wire connections are fine. Just be sure to twist and avoid any stray bits of wire.
  • Skormy
    Skormy Posts: 11
    Thanks for the tip.
    I was just concerned with the CS2 fitting at all. Anxious to see how tight the fit it is. 1/4" (or less) is not much wiggle room. If it doesn't fit, I'll repost and solicit opinions. Thanks much.
  • Theheadsn
    Theheadsn Posts: 413
    it should fit.
    I recently bought a cs20, pretty big mo fo, had to install a bigger shelf underneath my tv for it to fit. Worked out pretty well.
    youll be happy with what you have trust me, Im already blown away with just having the center channel done
    Home Theater Setup
    • Receiver - Onkyo TX-RZ1100
    • Mains - Polk RTi A9's
    • External Amps - Outlaw 2200 Monoblocks for L/R/C
    • Center - Polk CSiA6
    • Side Surrounds - Polk FXiA6's
    • Atmos - 4 Polk 80F/X RT's
    • Sub - SVS PC-4000
    • T.V. - LG OLED65C7P
  • ROHfan
    ROHfan Posts: 1,014
    On3s&Z3r0s wrote: »
    CS2 and CS20 have the same drivers.
    TV: 65" Samsung QLED 4K
    AIYIMA Tube T7 preamp --- Nobsound 12AX7 tube preamplifier
  • Skormy
    Skormy Posts: 11
    The CS2 fit like a glove -- literally, with less than 1/4" clearance after I put the feet on. Still need to run the audio cable, but I'm encouraged.
  • Theheadsn
    Skormy wrote: »
    yea might wanna get some help holding the speaker and trying to wire it in lol had to get the girlfriend to set the shelf for mine. Damn thing is like a brick
    Home Theater Setup
    • Sub - SVS PC-4000
  • inspiredsports
    inspiredsports Posts: 5,502
    reported post #29 spam from thalgetycle
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
  • inspiredsports
    post #22 reported - (from soon to be banned thalgetycle)
    NAD SS rigs w/mods
    GIK panels
