Polk monitor 60 or 70...rest of setup inside...help me choose.
@slammin.....I don't know about the sc line Onkyos, but my 807 is a TOASTER. It gets almost too hot to touch after a while, and all I drive with it, power wise, are the heights. I recommend giving any Onkyo avr plenty of breathing room.
Also...I do want me a pair of M70s...but I think I'm going to hang back until I can go 4ohm. I really can't make my TFM-45 sing with a pair of 60s, but I couldn't do much more with 70s"Making life enjoyable through expensive electronics." BillD
Pioneer Elite SC-57
M70 series 2 mains
CS2 center
M40 surround
M30 front height
SVS PB 12 NSD
Carver TFM-45 (mains)
Carver A753x (center, surround)
320GB PS3, 42" Panasonic G10,
M60's as a Zone 2 off of the Pioneer in the living room
R.I.P. Onkyo TX-NR807 -
Everything arrived...these towers are huge...and the center channel is a monster. LOL. They are much bigger than the 70's. I got it all hooked up but havent had a chance to do much with it yet.Receiver: ONKYO 709
Amplifier: Acurus A200x3
Front: EmpTek E55Ti
Center: EmpTek E56Ci
Surround: EmpTek E5Bi
Sub: Elemental Designs A5-350
TV: LG 55"
Blu-Ray: PS3 -
ibewbrother wrote: »@slammin.....I don't know about the sc line Onkyos, but my 807 is a TOASTER. It gets almost too hot to touch after a while,
I've got two of these on top of my 807, one does the job right now. In the summer when it's really hot, I run both.
http://www.buyextras.com/evavcoblfanf.htmlSet up: 11.2 HT + 2ch
When I was young, I was Superman but now that old age has gotten the best of me I'm only Batman -
I bought a rc270.
I was actually looking at one of the bigger heavier receivers, like the 807, but I do not have the room for it. The max I can go on height is 7"
Even with the 270 I am going to have to move the receiver to the bottom shelf because the middle shelf is only 6" tall.
That's too bad on space-A, the 807 has proved to be quite a performer for me this last year (purchased last Feb.) Pleeeeeenty of power on tap. I'm sure you'll find something that will suffice.
Nice stand btw, any chance of placing a larger receiver elsewhere?
Oops, sorry, I saw that you already got the 270.Set up: 11.2 HT + 2ch
These guys have some decent options as well:
http://www.coolerguys.com/compcooling.html
I personally like this one the best:
http://www.coolerguys.com/ccstandktc.html
Nice thing with them is you can also just buy the parts and use your own 120mm fans you buy so you can buy super high rpm ones if you want....."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
ibewbrother wrote: »@slammin.....I don't know about the sc line Onkyos, but my 807 is a TOASTER. It gets almost too hot to touch after a while, and all I drive with it, power wise, are the heights. I recommend giving any Onkyo avr plenty of breathing room.
Is that a TYPO. Because a TFM-45 is:
Simultaneous High Current / High Voltage Magnetic Field Power Amplifier. Our most powerful stereo amplifier designs with your choice of power output displays, that TFM - 42 and TFM - 45 can bring any speaker system under tight, authoritative control, yet with the warmth that rivals tube designs. Silver seven transfer function modified. 375 watts RMS / channel into 8 ohms, 20 - 20 KHZ with no more than 0.5% THD. 500 watts RMS / channel into 4 ohms, 20-20 KHZ with no more than 0.5% THD. 1000 watts bridged mono. TFM - 45 features analog power meters.
More than enough power for a set of M-60s. You don't need 4 ohm amps for M series speakers, they're an 8 ohm load?
cnh
No joke. My Carver 125x5 makes my 60's sing. I havent even been able to get it up to 0 on the dial yet for fear of retrobution from my neighbors....."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
I ran my old M70's off a receiver for awhile. Once i amped them they really came alive. The first one i used was a Rotel RB1070. Man that was a great little amp. Those 70's paired great with it. There's one for sale in the FM here right now i believe.Onkyo TX NR 5008 modified by The Upgrade Company
Oppo BDP 93 modified by The Upgrade Company
Arcam CD37
Monitor Audio Gold GS 60
Revolver Audio Music 5 towers.(surround)
Vandersteen V2W -
@cnh....I actually haven't had much time to listen, but I was referring to the fact that the 60's are rated at 225wpc and I'm powering them with a 375wpc amp. I just don't think I could improve my rig that much by upgrading to 70's. My 60's sound great with the A-753x...so I might not be used to the sound of the 45 yet."Making life enjoyable through expensive electronics." BillD
Pioneer Elite SC-57
M70 series 2 mains
CS2 center
M40 surround
M30 front height
SVS PB 12 NSD
This crap dwarfs the TV....think it is time to go bigger on that too.
I want to get an amp also.Receiver: ONKYO 709
Front: EmpTek E55Ti
TV: LG 55"
Blu-Ray: PS3 -
Now where have I heard that one before???????
Your set up looks waaaaaaaay cool. I have the same front three that you do (as probably 800,000 others here:biggrin:) and my CS2 is mounted on top of my 50" plasma, makes the screen look tiny, I told my wife that I needed to go up to 60", well, she won't let me have it in our bedroom but there's hope for when we relocate into something bigger
I'm also promised an XPA3 for my birthday, hmmmm, April 1st can't get here fast enough :biggrin:Set up: 11.2 HT + 2ch
you will love the XPA-3, it is fun amp.Home Theater:
Processor: Emotiva UMC-1
Amps: Emotiva XPA-3, Emotiva UPA-5
Center: Polk Audio CSi A6
Fronts: Polk Audio RTi A7
Surrounds: Polk Audio FXI A4
Surround Rears: Polk Audio RTI A3
Subwoofer: SVS 2039 PCi (upgraded woofer)
Power Conditioner: Monster HTS 5100 Signature Series
2 Channel: (work in progress)
Speakers: Polk Audio Monitor 40 -
Im searched for an answer to this and can't find a definitive one. Thus, I go with assumptions. The LSi series that uses the cascading crossover has a 200Hz LPF for the "subwoofer." No other speakers with the cascading array show their LPF.
Assuming the Monitor 70s LPF is somewhere around 200Hz, the 70s will still pair nicely with a true subwoofer that is crossedover around 80Hz. Or even 120Hz. At least this is what I am hoping...Music
LR: Polk Monitor 70 (willing to sell if interested)
C: Cerwin Vega E-75C
Sub: HSU VTF-2 MK3
AVR: Sony STR-DE835
AMP:
HT
5.1: Paradigm CT110
AVR: Integra DTR-4.6
WTB: RTiA9 or RTi12
