Calling All Cooks
  • Jstas
    Jstas Posts: 15,001
    edited February 2004
    One more that someone at work gave to me and I thought some one here might enjoy
    Hamburgers
    1 ¼ lbs. Lean ground beef
    ¼ lb. Andouille sausage
    1 large shallot, minced
    1 tsp fennel
    Mix together and form patties.   Grill over medium high heat,
    approximately 6 minutes per side, or until done to your liking.
    4 oil packed sun dried tomatoes
    ¼ c. mayonnaise
    1 tsp. Whole grain Dijon mustard
    Drain tomatoes and place in processor.  Add mayo and mustard
    and puree into a spread.  Refrigerate.  This can be made the day
    before.
    Large red onion, sliced into 1/3” slices
    Olive oil
    Brush slices with oil and place on grill for a few minutes each
    side.
    Sesame seed buns, split and toasted on the grill.
    Roasted red peppers, 4 oz. Jar, drained.
    4 oz. Asiago cheese, coarsely grated (I shredded and it worked
    fine)
    Now – the creation – Spread the toasted bun (both sides) with
    the sun dried tomato spread.  Place burger on bun, top with
    cheese, onion, red pepper and top of bun.  Enjoy!
    Expert Moron Extraordinaire
  • danger boy
    danger boy Posts: 15,722
    next time you want ground beef for burgers or any other dish.. look for ground sirloin. it's less fatty and tastes better on the grill than regular hamburger. you know when you go to the fair and smell the burgers they are grilling.. and wonder why they smell so good? they use ground sirloin.. it's expensive.. $4.00+ per lb. but worth it. ;)
    PolkFest 2012, who's going>?
  • Jstas
    Jstas Posts: 15,001
    Most people buy ground chuck which not only is very fatty but it's a very poor cut of meat, often stringy, tough and bruised. It's ok for ground beef or making stews and soups but for anything else it sucks.
    Ground sirloin is the only way to go and in everything I have ever made that called for ground beef, I use ground sirloin. Also, when cooking ground beef, ground sirloin is less likely to clump together and cook much more evenly than ground chuck because it is so much more tender and lean.
  • RuSsMaN
    RuSsMaN Posts: 17,985
    You guys up north are missing out, I use nothing but ground, free range Longhorn - NINETY EIGHT percent lean. Runs between $5 and $6/ pound, but oh so good AND good for you.
    Agreed on the Sirloin though, I wouldn't TOUCH anything *fatter*. When you are done forming patties, your hands shouldn't look like they are covered in Crisco.
    Oh, John, on the brine, where is the heat? The few times I have brined, the mixture ALWAYS gets heated just to a boil - then cooled BEFORE getting the meat involved. Just curious if they left that step out intentionally.
    Cheers,
    Russ
  • Jstas
    Jstas Posts: 15,001
    Cheers,
    Russ
    That is the way the recipe was given to me. I don't think it is supposed to be heated. It's worked that way before. I'll email the person who gave it to me and see if there is a step missing. I don't think so though.
  • danger boy
    If I can't find Andouille sausage around here.. any good substitute for it?
    I'm planning on making Jambalaya this weekend. :D
  • Jstas
    Jstas Posts: 15,001
    I don't know if there is a subsititute because Andouille is available here so I haven't had these burgers any other way.
    I posted a reciepe for Andouille sausage from Chef Folse below. Making it is difficult only because of the smoking involved but given the ingredients, you can get an idea of what other local available proccessed meat products will substitute well for texture and flavor.
    Andouille (pronounced "ahn-DOO-wee") is the Cajun smoked sausage so famous nationally today. Made with pork butt, shank and a small amount of pork fat, this sausage is seasoned with salt, cracked black pepper and garlic. The andouille is then slowly smoked over pecan wood and sugar cane. True andouille is stuffed into the beef middle casing which makes the sausage approximately one and a half inches in diameter. When smoked, it becomes very dark to almost black in color. It is not uncommon for the Cajuns to smoke andouille for seven to eight hours at approximately 175 degrees.
    Traditionally, the andouilles from France were made from the large intestines and stomach of the pig, seasoned heavily and smoked. In parts of Germany, where some say andouille originated, the sausage was made with all remaining intestines and casings pulled through a larger casing, seasoned and smoked. It was served thinly sliced as an hors d'oeuvre.
    It is interesting to note that the finest andouille in France comes from the Brittany and Normandy areas. It is believed that over half of the Acadian exiles who came to Louisiana in 1755 were originally from these coastal regions.
    5 pounds pork butt
    1/2 pound pork fat
    1/2 cup chopped garlic
    1/4 cup cracked black pepper
    2 tablespoons cayenne pepper
    1 tablespoon dry thyme
    4 tablespoons salt
    6 feet beef middle casing (see butcher or specialty shop)
    Cube pork butt into one and a half inch cubes. Using a meat grinder with four one quarter inch holes in the grinding plate, grind pork and pork fat. If you do not have a grinding plate this size, I suggest hand cutting pork butt into one quarter inch square pieces.
    Place ground pork in large mixing bowl and blend in all remaining ingredients. Once well blended, stuff meat into casings in one foot links, using the sausage attachment on your meat grinder. Tie both ends of the sausage securely using a heavy gauge twine.
    In your homestyle smoker, smoke andouille at 175-200°F for approximately four to five hours using pecan or hickory wood. The andouille may then be frozen and used for seasoning gumbos, white or red beans, pastas or grilling as an hors d'oeuvre.
    Recipe by:
    Chef John Folse
    Louisiana's Premier Products
    2517 South Philippe Avenue
    Gonzales, LA 70737
    (504) 644-6000
    Hopefully that will help out some. I'd imagine that some German sausages would subsititute well and maybe even some spicy Polish sausages would work too. You can always add the garlic, peppers and thyme as additional ingredients to the hamburger mixture if you have to substitute for andouille sausage.
  • Jstas
    Jstas Posts: 15,001
    Another recipe I tried that is good for grilling is this one from Alton Brown's Good Eats
    Stuffed Grilled Pork Chops
    Recipe courtesy of Alton Brown
    Show: Good Eats Episode: Chops
    Recipe Summary
    Prep Time: 15 minutes Cook Time: 12 minutes
    Inactive Prep Time: 12 minutes Yield: 4 servings
    4 double thick bone-in loin end pork chops
    1 cup salt
    1 cup brown sugar
    1 tablespoon black peppercorns
    1 tablespoon mustard powder
    2 cups cider vinegar, heated
    1 pound ice cubes
    1 1/2 cups cornbread, crumbled
    2 tablespoons golden raisins
    1/4 cup walnuts, roughly chopped
    1/4 cup dried cherries, halved
    1/4 cup buttermilk
    1/2 teaspoon ground pepper
    2 teaspoons fresh sage, thinly sliced
    1/2 teaspoon kosher salt
    In a plastic container put the salt, sugar, peppercorns, and mustard powder. Add the hot vinegar and swirl to dissolve. Let mixture sit for 5 to 10 minutes to develop flavor. Add ice cubes and shake to melt most of the ice. Add chops and cover with brine. Refrigerate for 2 hours.
    Remove chops from container and rinse. Cut horizontal pockets in each pork chop for stuffing. Combine rest of ingredients, and put into piping bag that is not fitted with a tip. Pipe each chop full with cornbread mixture. Grill the chops on medium high heat for 6 minutes on each side. Turn each chop 45 degrees after 3 minutes to mark.
    Follow the directions to the letter and they will come out perfectly! The only thing better than smelling them cook is eating them when they are done!
    BTW, Alton Brown is my favorite TV chef. Check out his show Good Eats on the Food Network. Not only does he show dishes that an ordinary person can make but he explains things like why you do certain things, what the history of foods is and what tools are for what and what and so on. It's an education more than a cooking show. Cheesey jokes and stuff too, it's fun to watch.
    Good Eats
    Good Eats airs Wednesday at 9:00 pm and 1:00 am and Sunday at 6:30 pm. Plus, catch additional episodes Monday through Friday at 11:30 pm and 3:30 am and Saturday at 8:30 am. All times ET/PT.
  • dorokusai
    dorokusai Posts: 25,638
    Pepperoni Rolls are indeed awesome. I have been chowing on those things for about 20 years. There is some old lady in WV, when we visit family, from which we buy about 50 of them at a time.
    I encourage that recipe very much, it is fantastic. Thanks for posting the others Jstas, they sound interesting.
  • Jstas
    Jstas Posts: 15,001
    Oh, I got plenty more! I gotta type in my mom's recipe for German potato salad still!
  • dorokusai
    Danger Boy - Chorizo sausage would also work nicely.
  • amulford
    amulford Posts: 5,020
    This is one of my all time favorites:
    Chilean sea bass done on the grill -
    Take a few nice pieces of chilean sea bass
    Make an open foil dish and put the fish in after drizzling w/ extra virgin olive oil (very lightly)
    Add to the top - chopped shallots, capers, pine nuts, small amount minced garlic, a half of stick butter cut into pats, a little fresh lemon juice, and a little white wine. Spice w/ a LITTLE salt and white pepper.
    Grill in alot of smoke (apple is good for this one) over LOW heat. be sure to leave the foil open. It won't take very long to cook.
    be careful serving for the fish will have a tendency to fall aparts. serve with the other ingredients on top.
    You have to try this one;)
  • amulford
    Try taking some four to eight ounce lobster tails and split the shell.
    put them in an foil dish
    Spice with a little adobo spice ( it's a spanish spice) and white pepper
    a tiny bit of minced garlic in each one
    2 pats of butter in each
    top off with a sprinkle of Hungarian paprika
    put on the grill w/ alot of smoke before you put on the filets.
    YUM YUM!;)
  • TheMaster
    TheMaster Posts: 184
    Quick and easy for a mouth watery recipe for your BBQ
    Marinated Pork Chops or Chicken
    - 2 cups of soy sauce
    - 1/2 to 3/4 cup of fresh lemon juice
    - 1/2 cup of chopped garlic
    - fresh ground pepper
    - 2 pinches of salt (BAM! BAM!)
    - mix all together with the meat and let it seat for a couple of minutes (I prefer 1 hour of marination) and throw it in a hot grill.
    Marinated Beef Chuck Steak
    - Give the steak a good massage with oyster sauce for 2 -3 mins.
    - let it seat in the frig for 1/2 hour to 1 hour
    - Pre-heat the oven in to a 350 temp for 5 mins. and bake the stake for 30 - 45 mins. (Tip: leave the stake alone in the oven for 30 mins before you before you start to check on it)
    take out a couple of beers or a glass of Sauvignon Cabarnet, play some nice songs and just enjoy the rest of your afternoon with your food.
    Glenn
    HT:
    DENON AVR-3803
    DENON DVM-1805
    SONY DVP-NS300
    SONY 36' HDTV Wega
    ADCOM GFA-555
    ADCOM GFA-555
    ADCOM GFA-2535
    ADCOM ACE-515
    POLK RTi70's (Bi-Amped)
    POLK CSi40
    POLK FXi30's
    POLK RTi38's
    POLK CSi20
    POLK PSW 450
    SVS PB2 Plus
    2 CH Stereo:
    AudioSource Pre/Amp 1
    Hafler DH-500
    Sony CDP-CX235
    Monster Cable HTS3500
    SDA SRS 2.3tl
  • danger boy
    found the Andouille sausage I was hoping to get for the Jambalaya i'm making tonight.. found it at some out of the way meat market.. I had to give them the super secret passward and enter thru the alley so as to make sure I wasn't being followed by anyone.. then i was strip searched to make sure i wasn't wired. :p
    just kidding. it did take some calling around though. i'll let you know how it turns out.
    DB
  • Jstas
    Jstas Posts: 15,001
    That's great Al! The Andouille sausage really makes the recipe IMO.
  • danger boy
    mmmmm. my jambalaya came out great.. found all the ingredients i needed.
    took longer to prepare than I thought it would be. Once it was all in the pot cooking.. it smelled great.
    taste was excellent. not much of a bite though... so I added some chili paste to add a little more heat. :p
  • wodom1
    wodom1 Posts: 1,054
    If you want to spice up your jambalaya and add some great flavor, you need to get some Tony Chachere's. Get the 'More Spice' Seasoning. That is some great stuff that is good on anything! I'm from South LA, from a town called Thibodaux, which is even farther South than New Orleans by 60 miles. I miss my spicy seafood since I moved to Chicago. Nothing like some good saltwater fish--red snapper, flounder, etc...
    Josh
    "I got into the music business thinking it was really radical, that it wasn't really a business at all, that it was a lot of people being artistic and creative. Not true, and it made me very depressed."
    Thom Yorke of Radiohead
    SOPA. Bow down before me, ****. Want a cookie?
    Polk Audio LSi15
    Polk Audio LSiC
    Polk Audio FXi30
    Samsung LN-T4061F 40" 1080P LCD HDTV
    Sony Playstation 3
    Outlaw Model 990 Pre/Pro
    Rotel 985 MK II
    Rotel 1072 CDP
    Soundstage Vacuum II tube pre
