adcom gfa 7300
Oldfatdogs
I just picked this up on ebay .I will hook it up this weekend to HARMAN KARDON AVR 25II .I have never hooked up a amp before is there anything I should watch out for?It didn't come with cables for hookup. Without starting another cable war what would be a good choice?Something to get things working until i can upgrade later.Does best buy or fry's carry something for starters?I have a week to return it if it doesn't work properly.
Best Buy has some interconnects from audioquest in their magnolia store. Though more expensive than what you can find them for online they have a decent selection if you can't wait.
I'd check out Signal Cables, I think they sound better than the lower line Audioquest cables, but like Grimmace said if you need something quick i'd buy some G snakes from Best Buy.
