adcom gfa 7300
Oldfatdogs
Oldfatdogs Posts: 1,874
I just picked this up on ebay .I will hook it up this weekend to HARMAN KARDON AVR 25II .I have never hooked up a amp before is there anything I should watch out for?It didn't come with cables for hookup. Without starting another cable war what would be a good choice?Something to get things working until i can upgrade later.Does best buy or fry's carry something for starters?I have a week to return it if it doesn't work properly.
  • grimmace19
    grimmace19 Posts: 1,429
    edited February 2011
    Best Buy has some interconnects from audioquest in their magnolia store. Though more expensive than what you can find them for online they have a decent selection if you can't wait.
  • B Run
    B Run Posts: 1,888
    I'd check out Signal Cables, I think they sound better than the lower line Audioquest cables, but like Grimmace said if you need something quick i'd buy some G snakes from Best Buy.
