basic wiring
My set up is yamaha rx 357 with tsi 300 fronts 100 center and 505 sub-there are four connectors on 300s which do I use.
  • BlueFox
    BlueFox Posts: 15,250
    edited February 2011
    If the four connectors are actually two pairs, and each pair is connected to the other via a jumper, then use whichever pair you want. Just make sure you wire plus(AVR) to plus(speaker), and minus to minus.
