basic wiring
raidernation 81
My set up is yamaha rx 357 with tsi 300 fronts 100 center and 505 sub-there are four connectors on 300s which do I use.
If the four connectors are actually two pairs, and each pair is connected to the other via a jumper, then use whichever pair you want. Just make sure you wire plus(AVR) to plus(speaker), and minus to minus.Lumin X1 file player, Westminster Labs interconnect cable
