Breathing Room for a CDP that uses Tubes
TORI3
TORI3 Posts: 234
edited February 2011 in 2 Channel Audio
Looking at purchasing a Jolida JD100 CD Player that has a tube output stage. Since I've never dived into tubes, my question is simple:
Does this type of CDP need breathing room if I were to put it into a relatively tight space? I only have 1" to 2" of room on top, but open space in the back and sides.
I tried searching, but didn't find much (as in nothing) on the net. Maybe it's just a case of common sense???
HT: RTi8s, CSi3, RTi4s, HSU ULS-15, Pioneer Elite VSX-23TXH, Sunfire Cinema Seven.
2CH: CJ MF2300, Parasound P3, PS Audio DLIII, Wadia 170i, Music Hall Maverick, Sierra-1s, Sunfire HRS8
Post edited by TORI3 on
  • Jetmaker737
    Jetmaker737 Posts: 1,103
    The manual states not to install as a built in unit or in a rack without proper ventilation. It also says not to obstruct the top. My unit sits in the open but doesn't produce very much heat. I would consider the installation you propose as OK.
  • dragon1952
    dragon1952 Posts: 4,907
    The manual doesn't have any specific measurements for ventilation, it just says not to obstruct the top portion and not to place in a built-in rack or installation that does not provide adequate ventilation. As long as their is and inch or two above and in an open rack such as yours it should be perfectly fine. The small preamp tubes don't put off all that much heat anyway.
  • dragon1952
    He types faster than I do :)
  • TORI3
    TORI3 Posts: 234
    That was really quick. Thanks Jet and Dragon.
  • TORI3
    TORI3 Posts: 234
    Jet, I see that you already have this unit. For others, here's the deal that I'm looking at.
    F1nut Posts: 51,674
    Most of the heat comes out of the top back right vent, but as the dragon stated, they don't put out a lot of heat. Two inches of clearance should be fine.
  • RuSsMaN
    RuSsMaN Posts: 17,986
    Looking for the 'Like' button, to click on the wisdom above instead of posting....
  • TNRabbit
    TNRabbit Posts: 2,168
    AIRFLOW. Fans can help if need be.
    TNRabbit
    NO Polk Audio Equipment :eek:
    Sunfire TG-IV
    Ashly 1001 Active Crossover
    Rane PEQ-15 Parametric Equalizers x 2
    Sunfire Cinema Grand Signature Seven
    Carver AL-III Speakers
    Klipsch RT-12d Subwoofer
  • TORI3
    TORI3 Posts: 234
    Thanks Rabbit. I've just started looking into fans out of sheer interest. I think I might try and put one in this weekend for my amp -- didn't even cross my mind for the CDP.
  • george daniel
    george daniel Posts: 12,096
    where is T_Unit when you need him:wink:
