Breathing Room for a CDP that uses Tubes
TORI3
Looking at purchasing a Jolida JD100 CD Player that has a tube output stage. Since I've never dived into tubes, my question is simple:
Does this type of CDP need breathing room if I were to put it into a relatively tight space? I only have 1" to 2" of room on top, but open space in the back and sides.
I tried searching, but didn't find much (as in nothing) on the net. Maybe it's just a case of common sense???
HT: RTi8s, CSi3, RTi4s, HSU ULS-15, Pioneer Elite VSX-23TXH, Sunfire Cinema Seven.
2CH: CJ MF2300, Parasound P3, PS Audio DLIII, Wadia 170i, Music Hall Maverick, Sierra-1s, Sunfire HRS8
The manual states not to install as a built in unit or in a rack without proper ventilation. It also says not to obstruct the top. My unit sits in the open but doesn't produce very much heat. I would consider the installation you propose as OK.SystemLuxman L-590AXII Integrated Amplifier|KEF Reference 1 Loudspeakers|PS Audio Directream Jr|Sansui TU-9900 Tuner|TEAC A-6100 RtR|REL T/9X SE Sub
The manual doesn't have any specific measurements for ventilation, it just says not to obstruct the top portion and not to place in a built-in rack or installation that does not provide adequate ventilation. As long as their is and inch or two above and in an open rack such as yours it should be perfectly fine. The small preamp tubes don't put off all that much heat anyway.2 channel - Willsenton R8 tube integrated, Holo Audio Spring 3 KTE DAC, audio optimized NUC7i5, Windows 10 Pro/JRiver MC29/Fidelizer Plus 8.7 w/LPS and external SSD drive, PS Audio PerfectWave P3 regenerator, KEF R3 speakers, Rythmik F12SE subwoofer, Audioquest Diamond USB cable, Gabriel Gold IC's, Morrow Audio SP5 speaker cables. Computer - Windows 10/JRiver, Schiit Magni 3+/Modi 3+, Fostex PMO.4n monitors, Sennheiser HD600 headphones
He types faster than I do
2 channel - Willsenton R8 tube integrated, Holo Audio Spring 3 KTE DAC, audio optimized NUC7i5, Windows 10 Pro/JRiver MC29/Fidelizer Plus 8.7 w/LPS and external SSD drive, PS Audio PerfectWave P3 regenerator, KEF R3 speakers, Rythmik F12SE subwoofer, Audioquest Diamond USB cable, Gabriel Gold IC's, Morrow Audio SP5 speaker cables. Computer - Windows 10/JRiver, Schiit Magni 3+/Modi 3+, Fostex PMO.4n monitors, Sennheiser HD600 headphones -
That was really quick. Thanks Jet and Dragon.HT: RTi8s, CSi3, RTi4s, HSU ULS-15, Pioneer Elite VSX-23TXH, Sunfire Cinema Seven.
2CH: CJ MF2300, Parasound P3, PS Audio DLIII, Wadia 170i, Music Hall Maverick, Sierra-1s, Sunfire HRS8 -
Jet, I see that you already have this unit. For others, here's the deal that I'm looking at.HT: RTi8s, CSi3, RTi4s, HSU ULS-15, Pioneer Elite VSX-23TXH, Sunfire Cinema Seven.
Most of the heat comes out of the top back right vent, but as the dragon stated, they don't put out a lot of heat. Two inches of clearance should be fine.
Looking for the 'Like' button, to click on the wisdom above instead of posting....Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service.
AIRFLOW. Fans can help if need be.TNRabbit
NO Polk Audio Equipment :eek:
Sunfire TG-IV
Ashly 1001 Active Crossover
Rane PEQ-15 Parametric Equalizers x 2
Sunfire Cinema Grand Signature Seven
Carver AL-III Speakers
Klipsch RT-12d Subwoofer -
Thanks Rabbit. I've just started looking into fans out of sheer interest. I think I might try and put one in this weekend for my amp -- didn't even cross my mind for the CDP.HT: RTi8s, CSi3, RTi4s, HSU ULS-15, Pioneer Elite VSX-23TXH, Sunfire Cinema Seven.
