Triggering a amp without a trigger???
jaritta
Hey guys, sorry about the slew of questions but I am trying to gather as much info as possible on building a ht room.
I have a acurus 3ch amp that i am wanting to include in my ht. It doesnt have a trigger port on it.
The way i understand triggers is that the amp remains in the on position and not supplying power to the speakers or consuming power until it gets signal from a reciever or pre-amp to supply the power to the speakers...right.
My question is, is it possible to trigger an amp that doesnt have a trigger port. I have done some very light reading and I had seen that some guys set up their rigs with a powerconditioner that can trigger the amp.... I didnt know if this would even be possible.
I guess i am just a little dumb when it comes to triggering a amp, I would like to leave the amp on ( in the on position) because i am setting up my ht componants in another room/or behind a cabnet.... again it isnt a big deal for me to get up to flip the amp power switch.
I can replace the amp with one with a trigger down the road if i need to but as of right now I will just get up to turn it off/on when i need.....because i cannot afford to replace it right now.
I would appreiate any help.
Fyi- my avr510 has a trigger out port on it.
Harman kardon signature 2.1 amp
Denon 3312
Epson 8700ub
Chief mount
Screen Innovations Performance Series 110in
Kef q 500 (RL)
Kef q 200 (C)
Kef q 800 (Rear RL)
REL T7 (SUB)
mx 450 remote
Sonos-Amp, Connect, Play5
Denon 3312
Epson 8700ub
Chief mount
Kef q 500 (RL)
Kef q 200 (C)
Kef q 800 (Rear RL)
REL T7 (SUB)
mx 450 remote
Post edited by jaritta on
Yeah, you can get a conditioner that can be triggered and that has delays on the ports so that not everything tried to come up at once. Short of modifying the amp to add a trigger circuit, this would be about the only way I can think of that you could do this.
Or you can just walk across the room and use the "manual trigger" method
Turntable: Empire 208
Arm: Rega 300
Cart: Shelter 501 III
Phono Pre: dsachs consulting
Digital: Marantz SACD 30n
Pre: Conrad Johnson ET3 SE
Speakers: SDA 2.3TL, heavily modified -
OR you can plug it in to the receiver switching outlet on the back(some newer ones do not have one) it it doesn't have to much amp draw.
That's a horrible idea.
Logically using a secondary amp is because it will have more power than the receiver, which will mean it will draw more power than the receiver.
The switched outlets on receivers only give maybe... 200w of power, which is piggybacked on the power cable of the receiver.
Also, receivers aren't going to support the IEC 3 prong plug.
The best idea is to get a power conditioner... My Tripplite has IR triggers for certain outlets. I just have to learn the commands for those switches onto my Harmony and it'll be golden.Main Surround -
Den - Rotel RSP-1068 / Threshold CAS-2 / Boston VR-M60 / BDP-05FD -
What model of tipplite do you have?Harman kardon signature 2.1 amp
Denon 3312
Epson 8700ub
Chief mount
Kef q 500 (RL)
Kef q 200 (C)
Kef q 800 (Rear RL)
REL T7 (SUB)
mx 450 remote
Sonos-Amp, Connect, Play5 -
This is what i was recommended, but havent bought one yet
As far as remote switching something that doesn't have a 12V trigger, I use one of these: http://www.compumusic.com/russound-110va....592-i471747.htmTV:Sony Bravia XBR4 52'
Mains: Lsi m 705
C:Lsi m 706
Rears: Lsi m 703
Sub: Epik Empire
Pre:Marantz AV 7005
Amp:Sunfire TGA-7400
Blueray: Opp 93
A/V Component: Panamax M5100-PM
Cables: Signal Cable, White Zombie, MIT, Pepster's power cables -
Sorry hear you go
Russound 110VAC/12VDC Triggered Outlet - 9500-115592
Russound 110VAC/12VDC Triggered Outlet 9500-115592 110 VAC - 12 volt DC triggered outlet with re-settable circut breaker. Switch to to 10 amps.,TV:Sony Bravia XBR4 52'
Mains: Lsi m 705
C:Lsi m 706
Rears: Lsi m 703
Sub: Epik Empire
Pre:Marantz AV 7005
Blueray: Opp 93
I have seen people using a Niles AC-3. It takes the 12v trigger and is said to be ok for power amps. http://www.amazon.com/Niles-AC-3-Voltage-Triggered-Power/dp/B00086IDDCPolk Audio SDA SRS 2.3TL
Parasound Halo A21
Parasound Halo P3
Home theater
Polk LSiM 707, 706c, 703, 705
Polk Blackstone TL3 for height
SVS PB12-ISD Sub
Denon AVR-X6400h
Parasound Halo A51
LG OLED65B7A
Sony UBPX800
Logitech Harmony Elite
PC LSiM 703
Spare LSIM 702 and 706c
Home Theater #2
Polk Audio LS70, CS350LS, LSF/X, S4
Onkyo TX-NR808 -
I have the Niles AC-3 and use it with my Parasound HCA-2200ii and it works well. My Denon receiver has two 12v trigger outs (3.5mm). One goes to my Parasound 2250 amp (3.5mm -> 2.5mm). The other goes to my other Parasound 1000A amp (3.5mm -> bare wire) and then to the Niles AC-3 (bare wire - bare wire).
So far no issues. Works like it's supposed to.Dali Optikon 1Mk2
NAD D3020 V2
Schiit Bifrost 2/64
..the rest are headphone setups. -
It looks like that Russound unit is about half the cost and uses jacks instead of bare wire. My only worry is it seems to be an import with no mainstream distribution like the Niles unit.Polk Audio SDA SRS 2.3TL
Parasound Halo A21
Parasound Halo P3
Home theater
SVS PB12-ISD Sub
Denon AVR-X6400h
Parasound Halo A51
LG OLED65B7A
Sony UBPX800
PC LSiM 703
Home Theater #2
Onkyo TX-NR808 -
Are there any reviews from customers? Yeah, the Niles was a little pricey and I perhaps didn't do an exhaustive search of alternatives.Dali Optikon 1Mk2
NAD D3020 V2
Schiit Bifrost 2/64
Not that I can find. Do a search and see what i mean. I doubt you will be able to return it to anyone.Polk Audio SDA SRS 2.3TL
Parasound Halo A21
Parasound Halo P3
Home theater
SVS PB12-ISD Sub
Denon AVR-X6400h
Parasound Halo A51
LG OLED65B7A
Sony UBPX800
PC LSiM 703
Home Theater #2
Onkyo TX-NR808 -
You're right - I'm not seeing any feedback for the Russound one. Absent any other alternatives, I will say that the Niles has more outlets (2 switched / 1 unswitched) for the extra $$. And I'd rather not take chances with my amp. Seems to be well built and the intention is to be used with audio components.Dali Optikon 1Mk2
NAD D3020 V2
Schiit Bifrost 2/64
I will probably buy a Niles soon. The manual trigger on my Adcom 555II is getting old.Polk Audio SDA SRS 2.3TL
Parasound Halo A21
Parasound Halo P3
Home theater
SVS PB12-ISD Sub
Denon AVR-X6400h
Parasound Halo A51
LG OLED65B7A
Sony UBPX800
PC LSiM 703
Home Theater #2
Onkyo TX-NR808 -
The Niles diff seems the way to go...Question what kind of wire i need to plug into my amp and end?
Thanks?TV:Sony Bravia XBR4 52'
Mains: Lsi m 705
C:Lsi m 706
Rears: Lsi m 703
Sub: Epik Empire
Pre:Marantz AV 7005
Blueray: Opp 93
Look for an Adcom ACE. It does the sequential turn on process and is triggered by a low wattage 120 receptacle on the back of the AVR, or a switched outlet.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
This one:
http://www.tripplite.com/en/products/model.cfm?txtModelID=3500
HT1210ISOCTR.Main Surround -
http://cgi.ebay.com/ADCOM-ACE-515-Power-Conditioner-Excellent-Condition-/290532407319?pt=LH_DefaultDomain_0&hash=item43a514b817
http://cgi.ebay.com/ADCOM-ACE-515-Power-Conditioner-/170603266363?pt=LH_DefaultDomain_0&hash=item27b8bf413b
http://cgi.ebay.com/ADCOM-ACE-515-AC-ENHANCER-POWER-SURGE-CONDITIONER-/220739741276?pt=LH_DefaultDomain_0&hash=item33651d265c
http://cgi.ebay.com/Adcom-ACE-515-AC-Enhancer-/250773976561?pt=LH_DefaultDomain_0&hash=item3a634b35f1
http://cgi.ebay.com/Adcom-ACE-515-AC-Enhancer-Power-Amplifier-Preamp-/220738394197?pt=LH_DefaultDomain_0&hash=item3365089855Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
Nice ben, thanks for the link to adcom....I know they are budget audio stuff, but i have always been a fan of adcomHarman kardon signature 2.1 amp
Denon 3312
Epson 8700ub
Chief mount
Kef q 500 (RL)
Kef q 200 (C)
Kef q 800 (Rear RL)
REL T7 (SUB)
mx 450 remote
