Triggering a amp without a trigger???
jaritta
jaritta Posts: 277
Hey guys, sorry about the slew of questions but I am trying to gather as much info as possible on building a ht room.
I have a acurus 3ch amp that i am wanting to include in my ht. It doesnt have a trigger port on it.
The way i understand triggers is that the amp remains in the on position and not supplying power to the speakers or consuming power until it gets signal from a reciever or pre-amp to supply the power to the speakers...right.
My question is, is it possible to trigger an amp that doesnt have a trigger port. I have done some very light reading and I had seen that some guys set up their rigs with a powerconditioner that can trigger the amp.... I didnt know if this would even be possible.
I guess i am just a little dumb when it comes to triggering a amp, I would like to leave the amp on ( in the on position) because i am setting up my ht componants in another room/or behind a cabnet.... again it isnt a big deal for me to get up to flip the amp power switch.
I can replace the amp with one with a trigger down the road if i need to but as of right now I will just get up to turn it off/on when i need.....because i cannot afford to replace it right now.
I would appreiate any help.
Fyi- my avr510 has a trigger out port on it.
Harman kardon signature 2.1 amp
Denon 3312
Epson 8700ub
Chief mount
Screen Innovations Performance Series 110in
Kef q 500 (RL)
Kef q 200 (C)
Kef q 800 (Rear RL)
REL T7 (SUB)
mx 450 remote
Sonos-Amp, Connect, Play5
  • quadzilla
    quadzilla Posts: 1,543
    edited February 2011
    Yeah, you can get a conditioner that can be triggered and that has delays on the ports so that not everything tried to come up at once. Short of modifying the amp to add a trigger circuit, this would be about the only way I can think of that you could do this.
    Or you can just walk across the room and use the "manual trigger" method ;)
    Turntable: Empire 208
    Arm: Rega 300
    Cart: Shelter 501 III
    Phono Pre: dsachs consulting
    Digital: Marantz SACD 30n
    Pre: Conrad Johnson ET3 SE
  • Ralphdole
    Ralphdole Posts: 3
    OR you can plug it in to the receiver switching outlet on the back(some newer ones do not have one) it it doesn't have to much amp draw.
  • nguyendot
    nguyendot Posts: 3,595
    Ralphdole wrote: »
    That's a horrible idea.
    Logically using a secondary amp is because it will have more power than the receiver, which will mean it will draw more power than the receiver.
    The switched outlets on receivers only give maybe... 200w of power, which is piggybacked on the power cable of the receiver.
    Also, receivers aren't going to support the IEC 3 prong plug.
    The best idea is to get a power conditioner... My Tripplite has IR triggers for certain outlets. I just have to learn the commands for those switches onto my Harmony and it'll be golden.
    Main Surround -
  • jaritta
    jaritta Posts: 277
    nguyendot wrote: »
    What model of tipplite do you have?
    Denon 3312
    Epson 8700ub
    Chief mount
    Kef q 500 (RL)
    Kef q 200 (C)
    Kef q 800 (Rear RL)
    REL T7 (SUB)
    mx 450 remote
  • bdtae5656
    bdtae5656 Posts: 235
    This is what i was recommended, but havent bought one yet
    As far as remote switching something that doesn't have a 12V trigger, I use one of these: http://www.compumusic.com/russound-110va....592-i471747.htm
    TV:Sony Bravia XBR4 52'
    Mains: Lsi m 705
    C:Lsi m 706
    Rears: Lsi m 703
    Sub: Epik Empire
    Pre:Marantz AV 7005
    Amp:Sunfire TGA-7400
    Blueray: Opp 93
    A/V Component: Panamax M5100-PM
    Cables: Signal Cable, White Zombie, MIT, Pepster's power cables
  • bdtae5656
    Sorry hear you go
    Russound 110VAC/12VDC Triggered Outlet - 9500-115592
    Russound 110VAC/12VDC Triggered Outlet 9500-115592 110 VAC - 12 volt DC triggered outlet with re-settable circut breaker. Switch to to 10 amps.,
    Mains: Lsi m 705
    C:Lsi m 706
    Rears: Lsi m 703
    Sub: Epik Empire
    Pre:Marantz AV 7005
    Blueray: Opp 93
  • Earthy
    Earthy Posts: 488
    I have seen people using a Niles AC-3. It takes the 12v trigger and is said to be ok for power amps. http://www.amazon.com/Niles-AC-3-Voltage-Triggered-Power/dp/B00086IDDC
    Polk Audio SDA SRS 2.3TL
    Parasound Halo A21
    Parasound Halo P3
    Home theater
    Polk LSiM 707, 706c, 703, 705
    Polk Blackstone TL3 for height
    SVS PB12-ISD Sub
    Denon AVR-X6400h
    Parasound Halo A51
    LG OLED65B7A
    Sony UBPX800
    Logitech Harmony Elite
    PC LSiM 703
    Spare LSIM 702 and 706c
    Home Theater #2
    Polk Audio LS70, CS350LS, LSF/X, S4
    Onkyo TX-NR808
  • PrazVT
    PrazVT Posts: 1,607
    I have the Niles AC-3 and use it with my Parasound HCA-2200ii and it works well. My Denon receiver has two 12v trigger outs (3.5mm). One goes to my Parasound 2250 amp (3.5mm -> 2.5mm). The other goes to my other Parasound 1000A amp (3.5mm -> bare wire) and then to the Niles AC-3 (bare wire - bare wire).
    So far no issues. Works like it's supposed to.
    Dali Optikon 1Mk2
    NAD D3020 V2
    Schiit Bifrost 2/64
    ..the rest are headphone setups.
  • Earthy
    Earthy Posts: 488
    It looks like that Russound unit is about half the cost and uses jacks instead of bare wire. My only worry is it seems to be an import with no mainstream distribution like the Niles unit.
    Parasound Halo A21
    Parasound Halo P3
    Home theater
    SVS PB12-ISD Sub
    Denon AVR-X6400h
    Parasound Halo A51
    LG OLED65B7A
    Sony UBPX800
    PC LSiM 703
    Home Theater #2
    Onkyo TX-NR808
  • PrazVT
    PrazVT Posts: 1,607
    Are there any reviews from customers? Yeah, the Niles was a little pricey and I perhaps didn't do an exhaustive search of alternatives.
    Dali Optikon 1Mk2
    NAD D3020 V2
    Schiit Bifrost 2/64
  • Earthy
    Earthy Posts: 488
    Not that I can find. Do a search and see what i mean. I doubt you will be able to return it to anyone.
    Parasound Halo A21
    Parasound Halo P3
    Home theater
    SVS PB12-ISD Sub
    Denon AVR-X6400h
    Parasound Halo A51
    LG OLED65B7A
    Sony UBPX800
    PC LSiM 703
    Home Theater #2
    Onkyo TX-NR808
  • PrazVT
    PrazVT Posts: 1,607
    You're right - I'm not seeing any feedback for the Russound one. Absent any other alternatives, I will say that the Niles has more outlets (2 switched / 1 unswitched) for the extra $$. And I'd rather not take chances with my amp. Seems to be well built and the intention is to be used with audio components.
    Dali Optikon 1Mk2
    NAD D3020 V2
    Schiit Bifrost 2/64
  • Earthy
    Earthy Posts: 488
    I will probably buy a Niles soon. The manual trigger on my Adcom 555II is getting old.
    Parasound Halo A21
    Parasound Halo P3
    Home theater
    SVS PB12-ISD Sub
    Denon AVR-X6400h
    Parasound Halo A51
    LG OLED65B7A
    Sony UBPX800
    PC LSiM 703
    Home Theater #2
    Onkyo TX-NR808
  • bdtae5656
    The Niles diff seems the way to go...Question what kind of wire i need to plug into my amp and end?
    Thanks?
    Mains: Lsi m 705
    C:Lsi m 706
    Rears: Lsi m 703
    Sub: Epik Empire
    Pre:Marantz AV 7005
    Blueray: Opp 93
  • ben62670
    ben62670 Posts: 15,969
    Look for an Adcom ACE. It does the sequential turn on process and is triggered by a low wattage 120 receptacle on the back of the AVR, or a switched outlet.
    Ben
  • nguyendot
    jaritta wrote: »
    This one:
    http://www.tripplite.com/en/products/model.cfm?txtModelID=3500
    HT1210ISOCTR.
    Main Surround -
  • jaritta
    jaritta Posts: 277
    Nice ben, thanks for the link to adcom....I know they are budget audio stuff, but i have always been a fan of adcom
    Denon 3312
    Epson 8700ub
    Chief mount
    Kef q 500 (RL)
    Kef q 200 (C)
    Kef q 800 (Rear RL)
    REL T7 (SUB)
    mx 450 remote
