KL-650-THX Klipsch ultra2
hangon
As a leading supplier of high-performance cinema speaker systems, Klipsch knows how to make the most out of film soundtracks and surround effects. The Klipsch KL-650-THX LCR loudspeaker brings that knowledge to the comforts of home. As part of the THX® Ultra2 family, this LCR reveals all the raw power and fine detail that the filmmakers originally intended.
* Front-firing port for low bass extension
* Dual 6.5-inch Cerametallic woofers
* 6- by 10-inch Tractrix® Horn Tweeter with 1-inch titanium-dome compression driver
* Top-of-the-line internal wiring
As the larger of the two LCR speakers in the Ultra2 family, the KL-650-THX features a front-firing port for low bass extension, dual 6.5-inch Cerametallic woofers and a new 6- by 10-inch Tractrix® Horn Tweeter. The tweeter driver is a 1-inch titanium-dome compression unit designed specifically for use with horns to provide high output with low distortion. The clarity and distinction of this LCR can also be attributed to its top-of-the-line internal wiring.
The KL-650-THX enclosure has the same dado and rabbet construction used in Klipsch professional speakers ensuring cabinet integrity in suspended applications. The Omni-Mount suspension points on this loudspeaker facilitate wall or ceiling mounting using standard hardware.
Available in a custom Galaxy black finish with an aluminum fascia, the KL-650-THX delivers the ultimate in power, detail and emotional impact from durable, easy-to-install cabinets.
Go to Klipsch.com for more information
KL-650-THX LoudSpeaker
$1,499.99* Each (MSRP)
ASKING $900.00 EACH
Attachment not found.
ASKING $900.00 EACH
HT Theater
SRS-SDA 2.3tl RDO's
Custom Center made out of a RTA15tl
Pioneer Elite SC-25 Receiver
CineNova Grande 5 channel Amp
Klipsch KA-1000-THX Sub Amp
(2)Klipsch KW-120-THX Subs
Basement System
SRS-SDA 1.2 upgraded Xover
ADCOM GFA 5500
ADCOM GFA 5503
Yahama P7000S Pro Audio Amp
dbx 120x-ds Sub-harmonic Synthesizer
2-JBL 4645C Subs
1-Paradigm SW2200 Sub
Klipsch Reference in wall's
SRS-SDA 2.3tl RDO's
Basement System
ADCOM GFA 5500
ADCOM GFA 5503
2-JBL 4645C Subs
Post edited by hangon on
Bump...still available....HT Theater
SRS-SDA 2.3tl RDO's
Basement System
ADCOM GFA 5500
ADCOM GFA 5503
2-JBL 4645C Subs
Klipsch Reference in wall's -
If you haven't already done so, I would list your speakers on Audiogon.- Computer Rig -
YAΘIN MS-20L, polkaudio RT5
- Main Rig -
Pioneer SC-37, Overnight Sensations, Samsung 52" LCD
- Currently In Progress -
Curt Campbell's Uluwatu LCR, LMS Ultra Gjallarhorn, JBL W15GTi stereo subs, 2.1 entertainment system for the gf -
You might also want to try the Klipsch Forum if you haven't done so.
Just listed them on eBay starting bid $1,500.00 for all (3)
Here is the Item number:120686488205HT Theater
SRS-SDA 2.3tl RDO's
Basement System
ADCOM GFA 5500
ADCOM GFA 5503
2-JBL 4645C Subs
I now have bidders, this is your last chance to bid
if anyone has an interest in them.HT Theater
SRS-SDA 2.3tl RDO's
Basement System
ADCOM GFA 5500
ADCOM GFA 5503
2-JBL 4645C Subs
