RTi800 and RT800 what's the difference?
I really don't know the difference between the RTi800 and the RT800 speakers. I have the RT800. Also I've seen an "i" attached to other speakers like mine. Also I have the RTFX surrounds but I have seen a 30 attached to the name to in this forum. What's the difference? Is this a good place to ask if anyone has a set of RTFX to sell? I'm new to this forum, bought my Polks in 2000 and love em.
Polk RT800 Main
Polk CS400 Center
Polk RT f/x Rear
Polk RT f/x Back Rear
Advent 12" powered sub
Sony STR-DA1000ES (7.1 amp)
Panasonic DV 563A (SACD, DVD ect)
DishNet Satellite(with hard drive rec.)
Sony36"WEGA(someday I'll get HDTV)
Kicks **** on a buget
Polk CS400 Center
Polk RT f/x Rear
Post edited by rstrine on
drivers- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
There's supposed to be a few small changes that might have an effect on performance, but nothing that should cause you to want to upggrade from the non-"i" to the "i" model. The most visible changes are the wood veneer on the outside and the blue cones on the drivers. Same thing with the RTfx's: No major difference. You might try the flea market forum, if you haven't already.
Welcome to the forum!
Jason -
from the non "i" too i the tweeter and crossover have been changed.
HBomb***WAREMTAE***
