TV died...suggestions?
Ethancf
Have a Mitsubishi WS-65...something or other. Great 65" TV that lasted me about 9 years. The picture now has a white washed look on all inputs, so I suspect a gun has failed or is failing. To invest in a new gun (granted that's the problem) would be a waste of money since the other 2 are probably close behind in terms of failure.
I would like to stay in the 65" + range, but am totally clueless what is good/bad, etc. Not sure of budget yet, just curious what your thoughts are in terms of OEM's and current technology. NO interest in 3D. Just Blu-ray and deep blacks.
Thanks,
Jason
Thanks,
Jason
THE SYSTEM
Polk Audio LSiM 707 Mains
Polk LSiM 702 f/x Surrounds
Polk Audio LSiM 706 C Center
SVS SB-17 Ultra Subwoofer
Rotel RSP-1582 Pre/Pro
Rotel RMB 1585 Amplifier
Oppo UDP-205 Blu-ray Player
Samsung PN64D550 64" Plasma
Post edited by Ethancf on
Unless you kept the TV in torch mode all its life I doubt the guns are the problem. If yopu could find a local Mits CRT guy it might not be as much as you think to repair but 12 years is about max on these.
In the 65" range check out the Mits DLP. Can be had for cheap and have a nice picture.
The 73" can be had for about $1600. Stay away from the 82"
If you want flat panal check out any of the panasonic plasmas in that size range.Speakers: SDA-1C (most all the goodies)
Even though you could care less about 3D, I think in the next release of TV's coming out, you may not have much of a choice.
You want a Bentley, it's going to come with power windows like it or not.65" Sony X900 (XBR-65X900E)
Pioneer Elite SC-37
Polk Monitor 70's (2)
Polk Monitor 40's (4)
Polk Monitor CS2
Polk DSW Pro 660wi
Oppo BDP-93
Squeezebox Duet
Belkin PureAV PF60
Dish Network "The Hoppa" -
If you get a picture of white I don't think your guns died. I'm thinking a video chip or a power supply problem.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
This is strange. I'm starting to agree with disneyjoe7. So I disconnected cables, tried different inputs, etc...same deal. I then pushed the power button on the TV on and off and it came back to life. After a few minutes or so it would fade out to a washed look again. Then I'd power on and off, and it would come back. It was taking a while longer to power up to "picture on screen." Power supply then? I think I may contact a tech if it continues.THE SYSTEM
Samsung PN64D550 64" Plasma -
If it worked on by repowering it I think a chip is bad.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Just replace it.. it's about time. IF you want big like that you're really looking at a projector or DLP from mitsubishi again.Main Surround -
Den - Rotel RSP-1068 / Threshold CAS-2 / Boston VR-M60 / BDP-05FD -
From the description it could well be cold solder joints. Get the old sodering iron out and start working :cool:This is strange. I'm starting to agree with disneyjoe7. So I disconnected cables, tried different inputs, etc...same deal. I then pushed the power button on the TV on and off and it came back to life. After a few minutes or so it would fade out to a washed look again. Then I'd power on and off, and it would come back. It was taking a while longer to power up to "picture on screen." Power supply then? I think I may contact a tech if it continues.
DARE TO SOAR:
Get a new one.If you can't hear a difference, don't waste your money. -
Get a new one.
Agree, fixing that old one now will only lead to more fixes down the road,given it's age. Bite the bullet and go shopping. If you want to stay in the 65 inch area it may get expensive though. Plasma from Panny, Samsung may be the cheapest way to go.HT SYSTEM-
lsi 9's -
Thanks,
Jason
Dell is selling this Mitsubishi 73" 1080p 3D TV for $1100:
http://accessories.us.dell.com/sna/productdetail.aspx?c=us&l=en&s=dhs&cs=19&sku=A4186750&~ck=dellSearch&baynote_bnrank=0&baynote_irrank=1Gears shared to both living room & bedroom:
Integra DHC-80.3 / Oppo BDP-105 / DirecTV HR24 DVR /APC S15blk PC-UPS
Living room:
LSiM707's / LSiM706c / LSiM702 F/X's / dual JL Audio Fathom F113's / Parasound Halo A51 / Panasonic 65" TC-P65VT50
Bedroom:
Usher Dancer Mini 2 Diamond DMD's / Logitech SB Touch / W4S STP-SE / W4S DAC-2 / W4S ST-1000 / Samsung 52" LN52B750
Other rooms:
Audioengine AP4's / GLOW Audio Sub One / audio-gd NFB-3 DAC / Audioengine N22
audio-gd NFB-10.2 / Denon AH-D7000 -
Thanks gents. I actually had a tech come out on Friday. Ended up being the 9 (I think) volt regulator. Had to order it from Mitsubishi and it should be done next week. When he was tinkering around he had me watch the screen and when he'd lightly tap on that component, the white washed screen would come and go. He said it would run under 2 bills to repair. That sound about right?
JasonTHE SYSTEM
Time for a new tv. I had a Sony rear pro tv, and had a problem with image retention back in 2006. Would have been 400 bucks for each gun to be rebuilt. It was more cost efficient for me to get rid of the Sony, and buy a Mits WD-Y65 from Circuit City Christmas Eve of '06. Save your money and put it towards that 73 inch Mits Dmara mentioned. That is a crazy price for a huge screen.polk monitor 70's
center - polk monitor cs2
surround - polk monitor 60's
surround back - jbl e10
sub - velodyne dps 12
sub - polk psw110
avr/pre-amp - onkyo tx-nr809
amp - adcom gfa-5500
amp - carver av405
display - sharp lc70le847u
tv - silicon dust hd homern
blu-ray - oppo bdp-103
hd dvd- toshiba hd xa2
control - logitech harmony one
turntable - technics sl1500 mkII -
Jason
Well, if you're going to save money, go ahead and push the TV as long as it will go. I'd get your learn on about replacements, though, so you know what you want if it fails again. New HDTVs will only get better and cheaper. So you're not really losing anything by waiting except enjoying a new set. -
More like if you want bigger than that. 60-65" plasma screens have great pictures and will take up far less room than the old TV. But then there's the cost...
If you want something really big like 80+", then you really have to look elsewhere.
