Spikes
TrashyTrucker
TrashyTrucker Posts: 225
edited February 2011 in DIY, Mods & Tweaks
This by far has been the cheapest and most simplest mod yet. I ask myself why I didnt do this long ago? I replaced the flat feet with spikes.
First, the vocals are more focalized, the bass is more defined and spark more detail. I listened to Robin Trower's "bridge of sighs" on MFSL gold cd and it was breathtaking! this is the best I have heard my srs sda 3.1 TL's as yet. The bass is no longer "boomy" I can testify to hearing the bassist bang his strings and the drummer hitting his bass drum as to now being two different instruments. No longer as just one as before.
All I can say is.... SDA owners! if you havent done this yet? do it now! This is NOT suptle.
edit: sorry cant upload pics right now.
Integra DTR 50.2 used as a preamp
Rotel RCD 1520 cdp
AudioQuest Jaguar 72v dbs ic's
AudioQuest type 8 wire
biamped to:
2-Hafler 9500 trans nova's
AudioQuest NRG-3 power cable's
dedicated AC line for
Tesla Plex 20a duplex receptacle
Panamax Max 7500 pro surge/line conditioner
SDA SRS 3.1 TL's modded...
spikes, rdo's, rings, dynamat, sonicaps, mills & aeon
Panasonic Viera G20 50" plasma
...SDA's are just like candy for your ears...
Post edited by TrashyTrucker on
  • thsmith
    thsmith Posts: 6,082
    Congrats, it is a good upgrade. Which spikes did you go with, better yet, pics !
  • TrashyTrucker
    Lasareath wrote: »
    Are the spikes digging into your floor?
    What kind of floor do you have?
    Sal,
    I have carpet...however you can get pads for spikes to use on your new hardwood floors too!
    thsmith wrote: »
    I went with cheapo Parts Express spikes. I cant upload pics tonight for some reason, it keeps saying upload failed when I try to attach.
    Rotel RCD 1520 cdp
    biamped to:
  • thsmith
    They work, who cares what they cost. Definately a overlooked upgrade.
  • TrashyTrucker
    Lasareath wrote: »
    I have the stock sliders on my 1.2tl's but my floors are wood and my speakers are 185lbs each. Not really sure if they'll make a difference.
    Ill admit I too was skeptical at first. But to my new experience, it will put your 1.2's into a whole new dimension. IMHO.
    Rotel RCD 1520 cdp
    biamped to:
  • Face
    Face Posts: 14,340
    Sal, they may make an upgrade in your case, but I'd avoid PE's spikes, you'll break them with those monkey coffins.
  • TrashyTrucker
    Lasareath wrote: »
    I too was skepticle at first. But with my latest discovery, you will not be disappointed. I truly beleive anyone with adjustable feet should benefit with this mod/upgrade. IMHO
    Rotel RCD 1520 cdp
    biamped to:
    Toolfan66 Posts: 18,164
    I say it all the time "SPIKE YOUR SDA's!!!!!!!!" it changes everything in the lower end of the SDA's. by far one of the best tweeks I have ever done..
    Sal, buy some good spikes with the pads for hardwood floors,as Mike said the ones from PE will be hard to hold the weight of the BIG BOYS. spend the extra cash for some nice brass ones..
    You can spike all SDA,s even if they don't have adjustable feet...:wink:
  • Cosmic_American
    Cosmic_American Posts: 114
    Does anyone know if the Parts Express spikes work with the CRS stands? If no what's a good way to spike them.
    2 channel:
    SDA CRS+
    Harman Kardon HK 3490
    Music Hall mmf-2.2
    F1nut Posts: 51,959
    Any spike with a 1/4-20 thread pattern will work on Polk speakers. That said, the large spikes at Parts Express are too large for the CRS stands. You want ones that are no more than 3/4" diameter at the top. Mye Sound sells them.
  • Cosmic_American
    Those look nice but I'm strapped for cash at the moment. These have the right measurements and they're dang cheap too, does the quality of the spike make a big difference in the sound? http://www.parts-express.com/pe/showdetl.cfm?Partnumber=249-727
    2 channel:
    SDA CRS+
    Music Hall mmf-2.2
    F1nut Posts: 51,959
    Many feel that the material makes a difference, with brass being the preferred choice. That said, spiked is better than not.
  • Cosmic_American
    Since this will be a very, very cheap upgrade I'll go with it. Maybe down the road I'll pick up some of the Mye Sound ones. Thanks.
    2 channel:
    SDA CRS+
    Music Hall mmf-2.2
  • sda2mike
    sda2mike Posts: 3,131
    one of the best upgrades i've made...definately not subtle
  • PolkMaster1
    PolkMaster1 Posts: 847
    I too was skeptical at first as I already had tremendous bass coming from my speakers, then the mortite, then the dynamat, then a speaker wire upgrade, then the inductor upgrade. How can spikes make a difference? Well, I gave it a shot with MyeSound MyeSpikes Brass and I am still hearing a difference for the better!!!
    Go for it Sal!!! Make sure you get it from Myesound. They are well worth it!!!
    Statistics show that 98% of us will die at some point in our lifetime.
    The other 2% will work for WalMart.
    F1nut Posts: 51,959
    I'm not sure. Call or email Grant and ask.
    Tony M Posts: 11,684
    Jessie, do you remember when you told me to GET MY SDA's OFF THE DOLLIES and SPIKE em?
    What a difference coming off of movable/rolling dollies. Best upgrade yet to my SDA-SRS2's.:biggrin:.......so far.
  • TrashyTrucker
    Lasareath wrote: »
    Will MYESOUND make the larger Spikes in 1/4-20 ?
    Sal,
    I talked with grant awhile back... He does make larger spike but not in 1/4 in. It will be perhaps 3/8 or 5/16 in. I cant remember which. So if you drill out for tee nuts etc. You are pretty much set in the larger dia. thereafter. I agree with Jesse that some spikes are better than no spikes. I will try to upload pics again.
    Matt
    Is anyone experiencing problems uploading pics?
    Rotel RCD 1520 cdp
    biamped to:
  • Systems
    Systems Posts: 14,872
    These are 1/4"-20 solid steel!
    I mean you will have to oil them or they will rust "solid steel"
    I bought 32 of them and have been impressed, fit stock RT-10 threaded inserts.
    http://www.parts-express.com/pe/showdetl.cfm?Partnumber=249-727&FTR=249-727
    Oops, guess I should have read the whole thread?
    Thought I was on to something there!
    Great deal for the money anywho!
    Testing
    Testing
    Testing
    pepster wrote: »
    Primer and Paint?:confused: no need to oil, who would want oil getting on their floor??
  • PolkMaster1
    Was the difference noticed when you took them off the dollies or when you spiked them? :biggrin::biggrin: Did you use Myesound Myespikes?
    When I took them off of the movers dollies, I turned them upside-down and fixed the bases and spiked at the same time.
    I used Parts express threaded inserts and their spikes. The original inserts were pretty much useless. The interconnecting sockets were useless also.
    I still need to get my RT3000P's off their dollies too. In time.:wink:
  • vc69
    vc69 Posts: 2,500
    I'm ordering spikes from myesound as soon I get a call back from them. Points and pads actually. I can't wait to hear the difference.
    Anybody know what I'm going to need in the way of T-nuts or will I be able to just screw them into the current floor pad threads?
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    Muscial Fidelity M1 DAC
    VTL 2.5
    McIntosh 2205 (refurbed)
    B&W 801's
    Transparent IC's
  • thsmith
    vc69 wrote: »
    I believe they are 1/4 20 but ask grant when you hear from him. For my 1Cs I needed T-nuts nit sure about your speakers
  • vc69
    vc69 Posts: 2,500
    Thanks. My Ls90's have threads for the floor pads. I don't know if that is stock or the previous owner put t-nuts in.
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    VTL 2.5
    B&W 801's
    Transparent IC's
  • Earthy
    Earthy Posts: 488
    My floor is the foam backed Pergo. Are spikes and pads still recommended?
    Polk Audio SDA SRS 2.3TL
    Parasound Halo A21
    Parasound Halo P3
    Home theater
    Polk LSiM 707, 706c, 703, 705
    Polk Blackstone TL3 for height
    SVS PB12-ISD Sub
    Denon AVR-X6400h
    Parasound Halo A51
    LG OLED65B7A
    Sony UBPX800
    Logitech Harmony Elite
    PC LSiM 703
    Spare LSIM 702 and 706c
    Home Theater #2
    Polk Audio LS70, CS350LS, LSF/X, S4
    Onkyo TX-NR808
    Earthy wrote: »
    With carpet just use the spikes, with hardwood floors or tile ect: use the spikes and pads..
  • TrashyTrucker
    Think they solved the UL pics problem
    So here are the pics finally.... thanks to Patrick!
    Matt :biggrin:
    Rotel RCD 1520 cdp
    biamped to:
