Signal Cable Analog One and Two
acmf74
I tried to do some searching but I didn't find anything pertinent. Does anyone have any experience between these two interconnects? Is there a significant difference between the two?
Thanks,
Thanks,
Post edited by acmf74 on
I've never heard the Analog ones, but I just put the two's in my system a week or 2 ago and they're awesome. When I called to order I asked Frank about the ones and he said the twos have smoother highs.
I´m using the ones to connect my NAD AVR to my amp, can´t comment on the two´s though, but I´m more than satisfied with the ones, good improvement over Audioquest G-snake, and the service is excelent.
